Mini Cooper Austin and Morris Mini talk, and the 2001-2006 Mini and Mini S, 2007 to present Mini and Mini S
Mini Cooper S F56 equipped with iPE exhaust | iPE Titanium Exhaust
Old Jul 6, 2016 | 12:41 AM
iPE Exhaust's Avatar
iPE Exhaust has a spectacular aura aboutiPE Exhaust has a spectacular aura aboutiPE Exhaust has a spectacular aura about
The Mini Cooper S F56 upgraded with an iPE system produces an extremely loud and aggressive growl for anyone behind the steering wheel who is searching for a spirited driving experience. With the in-line turbo engine design, our full systems incorporates a 200 cell high-flow sport catalysts down pipe to increase flow efficiency however at the same time being environmentally conscious, in addition prevent any engine check light. The titanium pipes will provide more efficient flow into our specially developed muffler which prevents torque loss under low revs, and providing maximum performance throughout the rev ranges. Our full Valvetronic exhaust delivers both performance and factory like regulations, all accessible via the valve control remote that uses 3 different modes: on, off and auto, to the driver's seat. In on mode, the valves are fully open for maximum flow and power, unleashing a unique and breath-taking sound of rumbles and burbles in low revs, through to loud growling in high revs, and with the flick of the sports button another level of crackling to popping after up shifting gears and lift off acceleration. In off mode, the valves are closed and volume is reduced to factory car like principles, maintaining legal sound restrictions where applicable for a comfortable cruise through quiet neighborhoods or for a passenger who has fallen asleep. The auto mode enables the system to detect the engine RPM and throttle pedal signal to automatically adjust the valve movements for an uninterrupted progressive driving experience.
Each part of the exhaust system is individually designed to perfectly fit onto the Mini Cooper S. Only the finest Titanium materials were chosen to reduce further weight and even more resistant to corrosion for the muffler internals to create a unique and breath-taking sound that will trickle those feelings and senses, sending them into your mind, giving you a bit of freedom away from the busy stressful working environment or for drivers who want a bit of attention grabbing sound.
The iPE Titanium Catback System
Each part of the exhaust system is individually designed to perfectly fit onto the Mini Cooper S -1
Each part of the system is individually designed to perfectly fit onto the Mini Cooper S -2
Each part of the system is individually designed to perfectly fit onto the Mini Cooper S -3
Muffler
Mid-Pipe
vettegood
Bentley
Mar 23, 2016 05:10 PM
PelicanParts.com
Mar 21, 2016 03:29 PM
BCS996TT
Jul 29, 2003 10:28 AM
996turbo
Jul 23, 2003 04:58 PM
AMG-ETR
Jul 20, 2003 09:35 PM
