100 octane unleaded in the South Sound?
Old Nov 30, 2009 | 05:39 PM
gigharbor1's Avatar
gigharbor1 has a reputation beyond reputegigharbor1 has a reputation beyond reputegigharbor1 has a reputation beyond reputegigharbor1 has a reputation beyond reputegigharbor1 has a reputation beyond reputegigharbor1 has a reputation beyond reputegigharbor1 has a reputation beyond reputegigharbor1 has a reputation beyond reputegigharbor1 has a reputation beyond reputegigharbor1 has a reputation beyond reputegigharbor1 has a reputation beyond repute
Anyone know where there might be a steady supply of this? I know there is a pump at Pacific Raceways, but it is $9 a gallon and the pumps are locked over the winter. I hear there is a place in Ballard, but I am hopeful there is something closer to where I live in Pierce County. Any help would be appreciated. Thanks in advance!
Old Nov 30, 2009 | 05:58 PM
CrazyRuskie's Avatar
CrazyRuskie has a reputation beyond reputeCrazyRuskie has a reputation beyond reputeCrazyRuskie has a reputation beyond reputeCrazyRuskie has a reputation beyond reputeCrazyRuskie has a reputation beyond reputeCrazyRuskie has a reputation beyond reputeCrazyRuskie has a reputation beyond reputeCrazyRuskie has a reputation beyond reputeCrazyRuskie has a reputation beyond reputeCrazyRuskie has a reputation beyond reputeCrazyRuskie has a reputation beyond repute
There is a 76 station in auburn that goes up to 114 octane (I believe) on Auburn Way.
Old Nov 30, 2009 | 06:00 PM
gigharbor1's Avatar
Thanks, Vasiliy. I will look into this!
Old Nov 30, 2009 | 07:13 PM
StorminS4's Avatar
StorminS4 has a reputation beyond reputeStorminS4 has a reputation beyond reputeStorminS4 has a reputation beyond reputeStorminS4 has a reputation beyond reputeStorminS4 has a reputation beyond reputeStorminS4 has a reputation beyond reputeStorminS4 has a reputation beyond reputeStorminS4 has a reputation beyond reputeStorminS4 has a reputation beyond reputeStorminS4 has a reputation beyond reputeStorminS4 has a reputation beyond repute
The 76 in Auburn carried (haven't bought it in a bit) the entire line of Trick Racing Fuels. And at far less than $9/gal.
But you can't run the 114 at all. Leaded gas.
Old Nov 30, 2009 | 09:03 PM
PJS's Avatar
PJS
PJS Is a GOD !PJS Is a GOD !PJS Is a GOD !PJS Is a GOD !PJS Is a GOD !PJS Is a GOD !PJS Is a GOD !PJS Is a GOD !PJS Is a GOD !PJS Is a GOD !PJS Is a GOD !
oh I think the new track toy can handle the leaded fuel... are you gassing up for tomorrow?
Old Dec 1, 2009 | 01:27 PM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
Looks like a great day today. Hope you have fun with the RSA Roman.
Old Dec 1, 2009 | 05:31 PM
Sl33p3rS4's Avatar
Sl33p3rS4 is infamous around these parts
It's not "far less" than $9 a gallon. I was there a few months ago and it was around $8.35 for the Trick 101 I believe.
1725 Auburn Way N, Auburn, WA‎
You can get the 101 unleaded directly out of the pump. I believe it's the pump in the south-western corner of their row of pumps.
They also have I believe 110 and 114 leaded available, but that has to be pumped into a container.
Old Dec 1, 2009 | 09:46 PM
gigharbor1's Avatar
Thanks a lot! Yes, this is the place. Vasiliy provided the phone number and I called to confirm. Thanks guys for your help.
For the record, the station quoted $8.45 for 100, while it was $9.70 at the track today. I ended up buying $275 of it at the track today (ouch).
PJ, I don't know all the science behind it, but I have been told that the motor in this car was built and mapped for 100 unleaded, and that I should not be using leaded nor should I be using 92. Damn!
Old Dec 1, 2009 | 09:55 PM
vincentdds's Avatar
The only reason why people avoiding leaded gas is that it can damaged your oxygen sensors or cats. I don't think a track purpose car like yours has cats on it. At least I hope it doesn't. Even if does and you're not worry about emission you'll be fine. If your car is tuned for 100+ you will not have any problem running anything higher then 100 leaded or unleaded gas. But why waste money if you don't need it.
Old Dec 1, 2009 | 10:08 PM
gigharbor1's Avatar
Thanks, Vince. The feedback I received from a local Porsche engine builder that knows the engine well is that using leaded would damage the O2 sensors. That's good enough for me. As for using 92 vs. 100, I can tell you that it runs like a banshee with 100, and still runs with 92 but it coughs and hiccups along the way (and with noticeably less power).
Old Dec 2, 2009 | 09:11 AM
speedneed's Avatar
speedneed is a jewel in the roughspeedneed is a jewel in the roughspeedneed is a jewel in the rough
in the long run 02 sensors will be cheaper then gas..
Old Dec 2, 2009 | 01:05 PM
StorminS4's Avatar
Wow... Inflation. I guess.
$8.45 is still better than $9.70, but for more than the $6ish that I would have assumed it should be. Isn't Avgas only $6.00 a gallon right now?
BlackMarketRacing
Dec 3, 2015 10:46 AM
turbotuner20v
Sep 11, 2015 12:02 PM
Sep 10, 2015 03:20 PM
