What's In The Shop Today At Elite Motorsports?
Carmine adores his GTI. In pursuit of more power he’s going APR Stage 2 but not before we address some minor issues like the leaking valve cover gasket and outside-front axle boots.[/URL]
Scott brought by his RS4 to have his custom upholstered Euro RS4 Recaros installed.
Martin had brought by his S5 coupe in for an alignment this morning shortly thereafter he brought his friend Frank in to get his wheels balanced.
Porsche 996 911 in for Rear Main Seal, Radio Repair and AC condenser replacement, brake fluid flush and alignment
3.2 V6 A6 came in for a VERY much needed carbon cleaning
Audi A4 Avant Major Service
MK6 GTI Getting ECU upgrade, short shifter, as well as Stage 2 APR intake. Very clean setup.
Lotus Exige came by for its yearly service, this one has 3800 miles on it. Awesome toy, getting in and out of it is interesting though…even for Kai.
The latest K04 upgrade from APR is extremely impressive. With the new 3-bar MAP sensor software and supporting modifications with the K04 turbo is the perfect combo for power and traction with the GTI FWD.
Mike’s Girlfriend’s Hyundai Genesis on Varrstoen Wheels gets the suspension dialed in for the SNTRL show
You don’t see garage kept clean MK4 GTI’s anymore…besides this one. Very clean and well kept GTI is here for a full timing belt service and various other maintenance items.
John dropped off his Gallardo earlier today with a CEL & running issues. Upon diagnosing the issue it was seen that one of his coil packs blew out. We replaced the faulty coilpack, made sure everything else was okay reset the service light & test drove the vehicle and it is operating to spec. We recommended he upgrade to the latest coil-packs & plugs at the next service. While the car was here he opted to do the oil & filter change and a look over on the other fluids of the Lambo.
This TT came to us with suspension creaking problems, upon diagnosing the issue we replaced the front sway bar bushings. While going over the car we found an oil leak which lead us to replacing the valve cover & cam adjuster gaskets. Client also took advantage of our brake fluid flush special ($99) and alignment special ($169) while the car was here as well as haldex flush & filter.
Tom’s SL63 is no slouch from the factory with 530 HP / 590 TQ on top of that he has the factory performance package which bumps him upto 557HP / 664TQ but that wasn’t enough so we opted to our friends at RENNtech to give him another 112HP / 70TQ on pump fuel. Watch out for this 670HP beast.
Audi’s S5 is already recognized for its high horsepower output and performance accolades but improving upon the horsepower can easily be realized using APR’s Stage 2+ upgrades. Chris took advantage of these upgrades and is now seeing 108HP gains over stock and 80lbs of tq on 93 octane.
Anthony drops off his Audi A4 for an oil change and to replace the diverter valve and crank pulley.
Having a high end alignment rack has allowed us to develop our strategic alliances among shops within the area. When a local performance shop needed a short notice alignment we were obliged to help. This 2014 Jeep Sahara came in driving sideways. It left pin straight.
Sean stopped by for a brake fluid flush using our EBS system before attending Watkins Glen track event over the weekend. We recommend doing this service every 2 years for street applications or before a high performance driving event
Taking Advantage of the APR Summer Sale, Jesus takes his 2011 VW GTI to Stage 1. As a man who recognizes value, he went with the fully loaded ECU that features 4 maps including stock, 93, 100 and valet.
We get asked this question all of the time, “how do you open up ECU’s?” Well, here you go. Enjoy!
http://youtu.be/oKPI2JCUBr4
When Nuni’s husband, Anthony, noticed some fluid in his driveway from under the 2001 Audi A4 he immediately brought it in for a leak diagnostic. After inspecting the sedan, the cause stemmed from a failed cooling hose flange. After we received authorization to replace the failed unit, it was immediately executed. A pressure test and test drive confirmed new unit was in working order without leaks.
Sean frequents the track and upon doing so items such as tires and brakes are wearing at an accelerated rate. Last week he had his brake fluid flushed and after a successful weekend at the track his tires needed replacement.
Keith dropped off his 2013 Audi A6 for an APR Supercharger Pulley and Stage 2+ Flash
Mercedes S550 stopped by for a tire swap (yes we mount & balance tires too!) & alignment during our special ($169 currently).
Billy brought us his 2004 Subaru STi for an alignment.
You may recognize Garrick’s A4 from previous shop updates. This time he brings us his Audi for a new power steering rack, power steering pump and New York State inspection.
Anthony came by from Vette Doctors with a client’s ZR1 for a track alignment coming up for an event this weekend at Monticello raceway.
You may remember Greg’s car from when he had previously come to us for an APR Stage 1 Flash. Furthering the performance of the GLI he had us pick up and install a Diesel Geek’s short shifter which shortens throws up to 25%.
After installing a MOMO racing steering wheel, Vinny needed us to adjust the toe to straighten out the steering wheel.
Tired of the OEM Grille, Alex Kaufman upgrades to an all black RS5 Grille.
http://blog.elitemotorsport.net/wp-c...teMS712_21.jpg
Jay comes to us from Teaneck, NJ to have his AWE Switchpath Exhaust Installed on his new Carrera S
One of our less advertised services include powder coating. Lou decided to spice up the look of his 2010 Chevrolet Corvette with red brake calipers and black wheels.
Our tire and alignment services aren’t exclusive to our German import focus. Rob swings through to get his have his tires mounted and balanced.
Kevin came by to have his APR RSC cat-back exhaust system installed we had ordered in store for him on his 2007 Volkswagen GTI.
Long time customer, Rich, stops by with his Chevelle.
“A carpenter is only as good as his tools,” and like the best carpenter with the best tools, we have the best alignment machine for our alignment tech. Chris had installed his coilovers on his BMW 335i and scoured the island for an alignment machine set into the ground to save his bumper from unnecessary damage.
Dameon was experiencing engine hesitation at all speeds and had stopped in for a diagnostic. After running the CELs it appeared one his ignition coils had failed. We had a used unit lying around and pulled the faulty ignition coil and temporarily fixed his car. Coils tend to fail in sets so we scheduled an appointment to have him come in to have all 4 replaced.
2011 Volkswagen GTI Stage 1 APR Flash
Phil dropped off his Audi A5 for Eibach Sportline Lowering Spring install.
Sami dropped off her drift 1991 Nissan 240sx hatchback for an spec alignment and rear tire mount and balance.
We lowered and aligned this low mileage, clean Mitsubishi Evolution 9
Another MK7 2015 Volkswagen GTI ECU Flash
We are happy to debut APRs ultimate engine control unit (ECU) upgrade for the Generation 3, 2.0 TSI engine as found in the MQB platform vehicles. APR’s ECU upgrade is available in octane-specific variations and is conveniently flashed to the vehicle’s factory ECU through the OBD-II port without any physical modification to the factory ECU!
Just wanted to say thank you to everyone who stopped at our booth at WaterFest 20 at Englishtown Raceway this past weekend.
Another customer realizes the power potential of the new APR Stage 1 MK7 VW GTI flash.
Marcin came to terms with his driving habits and decided to upgrade his braking performance with slotted front and rear rotors, front and rear pads and brake fluid flush.
2012 Audi S4 in for an APR Stage 1 flash.
Nicholas brought his EVO for a set of new pads & alignment during our summer alignment special. $169 till end of August!
Tony frequents the circuit and wearable items such as brakes and tires need to be replaced more often than pampered weekend drivers. We added stainless steel braided brake lines with new fluid complement the brake pad replacement.
These Gallardo’s have been through some extensive parking lot abuse with various rental events locally and we’re bringing them back to tip top shape whether it be tires, brakes, engine light fixes, and various other tweaks to get them ready for the weekend.
Peter dropped his beloved Volkswagen Passat for an overhaul including new brake pads in the front, timing belt, tensioners, water pump, clutch and flywheel, valve cover gasket, brake fluid flush and oil change. The car runs better than ever!
John came by for an alignment during our summer special.
Enzo Racing Lamborghini Superleggera 750R package alignment.
When your GTI is throwing CELs choose Elite Motorsports, the dealer alternative. Save by having an accurate diagnostic versus parts changing.
Many of our circuit racing customers utilize our in house tire mounting and balancing services while replacing other wearable parts.
Isaac came in for an oil change and inspection. Upon further investigation and the obvious coolant puddle, it appears the heater hose failed.
JoeEliteMS: BMW E46 M3 – Alignment
Nissan GTR Service
Lamborghini Clutch Replacement
2011 GTI APR Flash and Pirelli Tires
Lotus Evora Brake Fluid Flush and Coolant Flush
2004 Lamborghini Gallardo Ride Height Adjustment
Audi RS5 Suspension Mods
BMW E92 M3 – Powder Coating
Nissan GTR Service
