What's In The Shop Today At Elite Motorsports?
SubscribeBMW M6 stoppped in today for an alignment on our Hunter in-ground alignment machine.
We had these wheel powder coated black for Lorsel. He was ecstatic about the outcome given all the the rash on each wheel prior to repair.
Chan deliver us his B6 Audi A4 Quattro for a CEL. After a thorough diagnostic we revealed the car was is in need of some TLC. At 167k the A4 was in need of need spark plugs, air filter, cabin filter and drive belt, front and rear brake pads and rotors, coolant temperature sensor, front stabilizer bar (sway bar/anti-roll bar) end links and brake fluid flush.
Danny recently picked up this fetching 2007 Audi RS4 from EMG motors. After he had read on the forums of common shortcomings of the RS4 he promptly scheduled a carbon cleaning as he wanted the car to perform as good as new. While we had the car here for the carbon cleaning we completed an overall diagnostic of the vehicle to gauge its condition. We executed a 65k mile service which includes a fuel filter, spark plugs, cabin filter and air filter. We also found that the rear shock absorbers were blown of which we replaced. The brake fluid appeared to never been replaced so we had bled the system and filled with spec fluid. At this point in time one can say the car is “as good as new” as aesthetically it’s 10/10.
Tire Mounting and Balancing
Richard had brought in a timing belt repair kit for us to install.
Ken had dropped his 2008 Audi RS4 off because of a CEL relative to this intake manifold. It appears his intake runner flap arms had failed and we upgraded them with 034 motorsports intake linkage arms. We had removed the intake manifold in the process and revealed the car required a carbon cleaning. A thorough cleaning has the car performing 100%
Long time customer, George, delivers us his 2008 Audi A4 for complete diagnostic and maintenance.
jobs performed
-motor mounts
-oxygen sensor
-all 4 tires mount and balance
-alignment
-compression test
-leak detection pump
Audi RS7 – Diagnostic
jobs performed
-motor mounts
-oxygen sensor
-alignment
-compression test
Ranique executed an animal that managed to mangle the front lip, crack the bumper and crack the lower grill on his MK5 VW GLI.
We are Long Island’s best B7 Audi RS4 tuner by far. Further supporting the claim is this ’07 RS4 in for a new clutch, friction plate replacement, control arms upgrade, differential and transmission fluid flush and 4-wheel alignment.
Vinay stops by for a driver-front wearing bearing repair, new wipers and cabin filter.
S4 all buttoned up ready to roll.
Davis delivered us his ’10 VW GTI for suspension work, short shifter install and front spoiler installation but on his way over his spongy clutch pedal turned into a sunk clutch pedal. After removing the transmission, with his permission, the slave cylinder failed as we predicted.
Adrian dropped off his wife's Audi A4 for a new battery and oil change. She also mentioned an unusual noise coming from the suspension when it rains during hard turns.
Frank’s A6 experienced a catastrophic engine failure.
Milltek exhaust installed on a B5 Audi S4.
Looking for another A-technician!
05 Lamborghini Mercielago in for a start up issues.
This customer wasted no time going from stage 1 to stage 2.
Mike stopped by to have his 13 Audi A3 Quattro aligned.
Davin delivered us his 01 Audi TT Quattro for a heat issue diagnostic and oil change. After some adjustments the heat works great, the engine oil is fresh and a leaking exhaust was corrected by a flange gasket replacement.
2009 Audi A4 Quattro Cabriolet Engine Removal
13 Porsche Boxster winter wheel swap.
03 Jetta TDI Wagon oil change, New York State Inspection, passenger side axle, rear brake pads and passenger heated seat switch performed.
2004 Audi S4 – Timing Chain Service
Ian dropped off his 04 Audi A4 Quattro for an inspection, oil change, rear shock bellows replacement and diagnostic.
Xavier delivered us his 14 Jetta GLI for a forge motorsports diverter valve install.
Zach’s 04 S4 in for failing timing chain tensioner repairs. \
Andrew dropped off his 05 BMW 335i for a used remus axle back exhaust install with carbon fiber rear valence.
For Sale: 2010 Audi A4 Quattro 42k Miles Fully Loaded $15999
10 Mercedes CL550 taking advantage of our black friday alignment sale.
Progress Report- B6 S4 Timing Chain
Long time customer drops off his ’04 Audi A6 for a timing belt service, valve cover gaskets and upper control arms replacement.
Making some final adjustments to this 1997 Volkswagen GLX supercharger install.
2015 Volkswagen GTI – Oil Change
’13 Nissan GTR stopped in for Winter tires mount and balance and a 4 wheel alignment.
We had Lorsel’s wheels powder coated then we installed lowering springs, today, after the springs settled he took advantage of our Black Friday Week Alignment Special
05 S4 RS4 Grille Install, Oil Change, 115k Service, Upper Control Arms and Alignment.
$99 tire mount and road force balance until January 1, 2015.
For Sale : 2011 Audi Q5 Quattro 2.0T Premium 35K Miles $26995
RS5 owner capitalizes on our winter tire mount and balance and alignments specials!
“Blacula” in for a New York State Inspection and winter tire mount and balance.
Brendan and Ed stopped by to get Ed’s car alignment on his new winter tires and ride height.
Judy drops off her B6 A4 1.8T because her heat was not complying. After replacing the heater core the heat is on par with a warm summer day.
Leo remedies some of his A4’s problems by dropping off the car for a coolant/water pipe replacement and heater core.
Mk6 Volkswagen GTi transmission installation after rebuild.
Kyle balancing tires as part of our tire mounting and balancing special.
George was having a CEL for some peculiar reason beyond normal thought. After Sal’s diagnostic, the upper timing chain tensioners and guides were failing hence the intermittent code.
For Sale : 2005 Audi A4 Convertible 1.8T 155K
Phil brought his new GTI (not even 500 miles on it) to us for some upgrades. New wheels, suspension, boost gauge, intake, ECU flash and a few other touches here and there. End result is below.
2007 997.1 Porsche 911 Turbo oil change.
Matt capitalizes on our End of Year alignment special
Alex brought us a quote from another shop to have his 2009 Audi S5 wheels powder coated gloss black in response to our new “We Won’t Be Under Quoted” Campaign.
APR Stage 1 Flash on Dean’s 13 VW GLI.
Carol drops off her 2009 Volkswagen Beetle for a brake fluid flush and serp belts.
Keith drops off his 2004 Audi S4 Avant for an alignment and coolant temperature sensor diagnostic.
APR Stage 1 Flash on 2015 Audi S4
2013 Fiat Abarth – Alignment
2015 Audi A3 – Alignment
2001 Audi S4 Stage 3 – Alignment
Mike brings to us his 2013 Audi A5 Cabriolet for lowering springs, front and rear sway bars, RS5 Black and silver grille and alignment.
2010 VW GTI oil change.
2008 VW R32 in for our all wheel alignment special going on until the New Year!
AWE dual single tip cat-back exhaust system installation on Andre’s 13 Audi A4 Quattro 2.0T.
Jose stopped by after his 1997 Porsche Boxster had an air leak in the right rear tire following another shop’s mount and balance.
Chris’ friend brought in his GTi for an alignment and oil change.
2002 Audi A4 Quattro 3.0 V6 6 Speed 143K Miles $4999
35% tints and gloss black powder coated wheels for this 2015 Audi A3 owner.
AWE Exhaust install on Xavier's 2014 Volkswagen GLI.
Alex went to a local shop thinking an axle install should be a simple enough job where he could get a good a value on the install. Following the install his axle had backed out and they had reinstalled it. Upon doing so they damage the gear upon which his speed sensor works upon causing his speedometer to work incorrectly upon deceleration. Needless to say he came by for a repair diagnostic and repair.
Chris had just picked up his ’14 Audi Q7 in Florida and brought it to New York. To make his Q7 unique he had us install his mudflaps, running boards and window visors.
This GTI had a considerable oil leak. After a thorough investigation we had sourced where the leaks were stemming from but being about details we had insisted the timing belt, axle boots and tires, due to alignment, be rectified as well before more expenses be incurred in the event of a failure.
2013 Audi A5 H&R rear sway bar installation and alignment after last week’s lowering springs install had settled.
APR pulley and Stage 2 Flash on this B8 S4.
Erik and Thaddeus installing the DXD Stage 2 Daily Clutch and new long block into the 2011 Volkswagen GTi.
Sal rebuilding the bottom end on a 13 BMW 328i.
Cynthia in for control arms replacement on her 2006 Audi A6 Quattro.
Kai executing an APR stage 2 flash on a 13 VW Golf R.
Sal and Thaddeus making progress on the the 2013 BMW 328i engine rebuild.
We are installing a right rear radiator on our Murcielago project after determining a leak over-time.
KW3 coilovers, H&R FSB and RSB installation on a 2014 Audi RS5.
Jamal dropped his 2005 Audi A6 4.2L off for service because he was being mislead by the local dealership. After composing a considerable list of must do repairs we began with valve cover gaskets, vacuum leak repair, brake fluid flush, hood shock and module reprogramming.
APR Stage 2+ ECU flash and pulley installation on this 2011 Audi S4.
120k miles service, vacuum pump gasket leak repair and oxygen sensor bung and sensor replacement as their was not a bung welded on his custom exhaust from the previous owner.
Air intake filters and oil change on Angelo’s wife’s 2006 Porsche Cayenne Turbo S.
Arty was having a difficult time addressing his battery draining issues after he had tested the alternator and replaced his battery. The car had a subtle smell of mildew but beneath the carpet existed not a single module nor standing water. After checking for a parasitic loss we discovered that there was a 3 amp draw. We had then pulled fuses to isolate where the draw was stemming from. Sal had discovered that the draw came from the aftermarket radio blue tooth module.
Jose, owner of a 97 Supercharged Porsche Boxster, dropped off his 2013 Jeep Wrangler Rubicon off for an oil change.
John’s GTI had just came in for some software upgrades, upon installation of the software we had discovered that his turbo oil drain line and cam position sensor was leaking. We replaced the position sensor and drain line gasket as well as performance an APR stage 2 reflash.
Matt came to us with his blue 2010 Mini Cooper S (turbo!) He was experiencing an oil leak when parking the car in the drive way and came to us for aid. The oil leak was due to a leaking valve cover, oil pan gasket (common) and timing chain tensioner washer failure. We addressed each issue and aligned the “dime turner.”
Manny experience a minor accident resulting in a sever oil leak. Unable to identify the source he called upon us to rectify the concerns. Upon discovering the oil leak we also found his axle damaged.
Replaced axle and repaired oil leak.
B]Costas’ S4 came in with steering issues, we determined it needed a new pump & rack. After replacing both parts we aligned it on our rack and delivered the car to him. [/B]
Mercedes C300 in for scheduled maintenance.
APR stage 1 Flash on this 2015 Volkswagen GTI.
H&R OE lowering springs being installed on Albert’s 2015 Audi S4.
