Excelerate Performance: Northeast Audi & VW Performance and Service Center
Old Sep 8, 2015 | 02:25 PM
  #241
ExcelerateRep's Avatar
ExcelerateRep is infamous around these parts
The owner of this Mk6 Golf R came to Excelerate Performance to have us install his coilovers and perform an alignment.
This B8 S4 swung by the shop for some regular upkeep! Treat your Audi right, and it will treat you right in return.
Too many AWE Tuning Exhaust Installs in a week? BLASPHEMY! Installing a Track Edition on this Gen 3 GLI along with an APR Carbon Fiber Intake.
This B8 S5 4.2 came to Excelerate Performance to have an AWE Tuning Touring Edition exhaust and S-Flo Intake installed. To top this ice cream sundae off, we flashed the car with JHM software!
Old Sep 14, 2015 | 09:52 AM
  #242
Hey local customers! Cash in on some free labor when you pair APR software and Intake in a combined purchase, and get that intake installed for free!
* Install exclusions apply
- Add $50 to these platforms MK4 1.8T, B6 A4 1.8T, B7 A4 2.0T, VR6, 1.9L TDI, mk5 2.5L.
Old Sep 18, 2015 | 02:13 PM
  #243
This B7 S4 came to Excelerate Performance for a set of H&R coilovers, SPC adjustable upper control arms and an alignment by Excelerate
Purchase the coilovers via our website
here
http://vag.excelerateperformance.com.../i-239481.aspx
and the control arms for your B6/B7/B8 here! (2 required per car)
http://vag.excelerateperformance.com...i-1829759.aspx
Old Sep 21, 2015 | 11:07 AM
  #244
A couple Big guns on deck this week! B7 S4 in for a timing chain service and a C5 RS6 for some exhaust work! Stay tuned!
Old Sep 23, 2015 | 02:26 PM
  #245
This super clean CC came to Excelerate Performance for an APR Stage 2 flash upgrade to compliment the APR downpipe!
Old Sep 25, 2015 | 07:42 AM
  #246
Pressing out the factory worn rubber bushing
Installed are the new IPD adjustable camber bushings
Contact us today for an alignment and tire mount and balance quote! Lowered? No problem! Expensive wheels? No problem! Have your car aligned on our low profile Hunter alignment rack, and have your tires mounted to your expensive wheels without a scratch. Delivery the highest quality service.. bar none.. in the state of Connecticut.
Old Sep 29, 2015 | 12:54 PM
  #247
2013 Tiguan in for APR LLC's Stage 1 flash!
E90 328i in search of a smallbump in power from Active Autowerke!
MK4 20th in for a 42 Draft Design's turboback exhaust
Most tuned MK6 and Mk7's with a manual transmission will be in the predicament sooner or later HS Tuning RSR clutch for this GTI
Allroad Airride Woes! Anyone who owns one of these wagons knows all about this.. Replacing the Arnott Gen 1 bags with the updated series replacements to cure leak issues.
I think we found your problem! [o_o] Cases like these are why you must take your car to a professional. Using proper equipment to diagnose an issue properly is key. This car ran pretty well and only had a code or two which turned out to be more serious than initial anticipated.
Old Sep 29, 2015 | 01:00 PM
  #248
The owner of this awesome Mk7 GTI came to Excelerate Performance for the next steps in his ultimate Autocross class crusher dreams. We installed VWR springs, VWR100006 wheels while swapping over his well abused PSS tires to the new wheels for the remainder of the season! Topping the suspension work off was an alignment. Our mechanics also installed APR's solid shifter bracket, VWR's shortshifter and 42 Draft Design shifter bushings to help keep the slop to a minimum while racing.
Old Oct 1, 2015 | 11:15 AM
  #249
Installing a set of 034 Intake Manifold Linkage arms on an 08 RS4!
An alignment today for this 2.7T Allroad
This B6 A4 1.8T came to Excelerate Performance because he was experiencing clutch slip issues. Its safe to say without driving the car this clutch was well used just by looking at it. Check out the spotting and color change from the clutch overheating!
Up next on the chopping block! B7 S4 in for timing chain replacement.
One of my favorites from the week, this gorgeous Sepang Blue SQ5 in for APR, LLC Stag 1 software. Be on the lookout for more of this SQ in the future for the stag 2 pulley upgrade, AWE Exhaust and a set of wheels for the spring time!
Old Oct 2, 2015 | 01:52 PM
  #250
This Lovely Q5 3.0TDi who belongs to a very close customer of ours wanted some more power from his wife's daily driver
This B6 A4 1.8T received a lovely gift today! Thanks to APR and Carbonio for the Intake!
Diagnosing a misfire condition on this E90 BMW 328xi too.
Old Oct 2, 2015 | 01:55 PM
  #251
This C7 S7 came to Excelerate Performance for an Akrapovic Titanium Exhaust system, AWE S-FLO Intake, and APR, LLC's Stage 1 ECu and DSG software upgrades! This thing is a land rocket now and sounds amazing!
Old Oct 5, 2015 | 02:08 PM
  #252
Performing some necessary tests before the engine comes out of this B7 S4 for Timing Chains as our mechanic attempts finding TDC.
Old Oct 8, 2015 | 02:14 PM
  #253
Look at these two beauties. 2015 S4 and 2013 S7 get the APR, LL treatment! The S4 gets stage 1 and the S7 gets a full round of ECu and DSG calibrations!
Only one day left on the APR sale!
Old Oct 9, 2015 | 08:33 AM
  #254
One of our great customers brought his MK7 Golf R back to us to have a downpipe installed and State 2 re-flash as well as some aerodynamic side skirt and front splitter accessories installed.
A Mercedes C-Class and 2.7T Allroad also visits headquarters yesterday for some diagnostic and service work.
We don't typically work on pre OBD2 vehicles and if we do its not often, but this Eurovan Camper was way too cool... plus it was super clean and fresh to the Northeast from Arizona. The brake line nuts even broke free without any fuss. We could get used to this!
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
ECS Tuning - BMW
Aug 19, 2015 01:35 PM
ECS Tuning - BMW
Aug 19, 2015 01:22 PM
ECS Tuning - BMW
Aug 19, 2015 11:19 AM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
