Excelerate Performance: Northeast Audi & VW Performance and Service Center
Old Jan 16, 2015 | 11:46 AM
  #91
ExcelerateRep's Avatar
ExcelerateRep is infamous around these parts
Making good use of our new SnapOn charging system while flashing APR ECU and DSG software. It's important to maintain proper voltage to the ECU and we spare no expense when it comes to tools and equipment.
Old Jan 16, 2015 | 11:47 AM
  #92
Here is a close up image of one of the specialty tools required in the Audi 3.0T high boost supercharger pulley upgrade.
Old Jan 16, 2015 | 11:48 AM
  #93
Among a number of other projects today we flashed a MK 5 Jetta 2.0 TDI today with APR, LLC. software, and installed VWR springs on a 2013 Golf R.
  #94
In typical APR, LLC. fashion, a complete, plug and play solution for a boost gauge for the MK7 Golf, GTI, Golf R has been designed. There is no wiring or cutting with this setup. Just a plug and play setup.
APR's pleased to present the MK7 Golf, GTI and Golf R Vent Mounted Boost Gauge System!
The APR Boost Gauge System features a high quality and accurate electronic 52mm gauge with smooth and precise movement thanks to microprocessor driven stepper motor. The gauge’s anti-fogging polycarbonate lens allows reliable vent-mounted operation without fogging as is common on units without this design specification. Visual design cues were borrowed from the MK7 Golf, GTI and Golf R instrument clusters to deliver a dimmable LED backlit face with multiple needle colors that look right at home within the vehicle’s interior. The gauge seats neatly inside a high-quality injection-molded vent mounted pod, resembling the OEM design, allows airflow to continue past the unit and still allows operation of the vent airflow control.
APR’s plug-and-play wiring harness eliminates the headaches typically associated with integrating gauges into the factory system. The harness simply plugs into the gauge and into the factory wiring harness, eliminating the need to cut, splice and permanently alter the factory wiring with specialty tools. It’s quick, simple, and carries the quality one would expect from APR.
A high-resolution 3 Bar MAP sensor mounts conveniently and tidily within the engine bay on a simple and effective firewall mounting bracket and provides the gauge with a means for reading boost and vacuum signals. OEM style wiring harness covers protect the wiring harness and provide a cleaner install and appearance. The MAP sensor needs a physical reference line to the intake manifold, and as such, APR recommends the APR Boost Tap System as the preferred delivery method.
Read More:
http://www.goapr.com/products/boost_gauge_mk7_golf.html
Old Jan 16, 2015 | 11:49 AM
  #95
We stayed busy today here at Excelerate Performance and flashed five VW 2.0T TSI cars with APR, LLC.! Remember, we flash software without appointments, and using the OBD port means it's less than 30 minutes to get sometimes as much as 40-50% gains over stock.
  #96
One of two of the B7 RS4's we have here at Excelerate Performance. Here we removed the timing covers to inspect the timing chains and guides.
Old Jan 16, 2015 | 11:50 AM
  #97
We already had a few MK6 GTis in for APR upgrades. This Golf R is getting APR software and a boost gauge.
  #98
We installed new rear springs on the KW suspensions coilovers on this B8.5 S4 3.0T. Once completed, it required a proper alignment with our Hunter Hawkeye Elite Alignment system.
Old Jan 16, 2015 | 11:51 AM
  #99
The APR sale is in full force and many are taking advantage of it. We are flashing @aprllc software through the OBD port in less than 15 minutes and with no appointment.
  #100
ADV.1 Wheels MV2 20" wheels in a brush smoked finish wrapped in Pirelli P Zero tires, mounted and balanced on our brand new Hunter Auto34 and Road Force Touch Balancer machines.
Old Jan 16, 2015 | 11:52 AM
  #101
Check out our specialty tools we used to prep this input shaft for installation on a B7 RS4 that's getting a transmission rebuild and along with an engine overhaul.
Old Jan 16, 2015 | 11:59 AM
  #102
The Akrapovic Exhaust System we installed on a customers C7 S6 features titanium mufflers, noise-control exhaust valves, and carbon fiber tips.
Old Jan 16, 2015 | 12:01 PM
  #103
A loyal customer of ours here at Excelerate Performance had brought us his B7 RS4 for a clutch. Once the transmission was removed from the car, our technicians discovered excessive wear on the input shaft. So, the clutch was replaced with a JHM 3R unit alongside a JHM Shifter, Stabilizer, and Linkage. Since the transmission was removed it made the decision to add Apikol transmission mounts and rear differential mount that much easier. Once the lift was lowered the RS4 was pulled onto our state of the art Hunter Engineering Hawkeye alignment rack. To top off the build, Josh flashed the car with APR, LLC. software.
-Greg
  #104
Paul's spicy yet tasty Misano Red B7 RS4 came in for similar transmission issues like is Sprint Blue Brother above among other things. This car also received the JHM 3R clutch kit, syncros one and two, and 2second gear was also replaced. Like any 4.2L Audi V8, the engine was thoroughly inspected it while it was out as a precautionary measure. Attention to detail is what Excelerate Performance is about.
Old Jan 16, 2015 | 12:04 PM
  #105
B8 S5 Cabriolet in for a fuel injector service and carbon cleaning. If you own a direct injected car, please call us for an estimate to perform this service to your car.
