Excelerate Performance: Northeast Audi & VW Performance and Service Center
Old Jan 16, 2015 | 10:48 AM
  #46
ExcelerateRep's Avatar
ExcelerateRep is infamous around these parts
This '06 Jetta GLI came in for some important maintenance, including carbon cleaning of the valves. Check out the before and after picture, what a difference!
  #47
Installed these 3SDM wheels, slotted StopTech rotors and street performance pads, as well as ST suspensions coilovers on this MK5 GTI. What do you think of this unique look?
Old Jan 16, 2015 | 10:50 AM
  #48
Another APR, LLC. update. If we didn't have software before for you, we do now. Contact us to schedule an appointment.
2013+ Volkswagen CC, Tiguan and GTI 2.0 TSI ECUs Now Supported!
APR is pleased to announce previously unsupported 2013+ model year Volkswagen CC, Tiguan, GTI and other model 2.0 TSI ECUs now support APR’s DirectPort Programming.
DirectPort Programming enables the vehicle’s ECU to be flashed through the OBDII port without removing and opening the case. This also opens these vehicles to APR’s line of performance software and hardware from APR Stage 1 ECU upgrades all the way up to APR’s Stage 3 GTX Turbocharger Systems!
To read more about APR’s product lines for these vehicles please visit each vehicle’s product selection page:
CC: http://www.goapr.com/products/?vehicle=CC
Tiguan: http://www.goapr.com/products/?vehicle=Tiguan
Golf GTI: http://www.goapr.com/products/?vehicle=Golf_MKVI
More powah via a software update for the APR, LLC. Stage 3 GTX kit with the additional of the APR Low Pressure Fuel Pump upgrade.
APR is pleased to present the Stage 3 GTX Low Pressure Fuel Pump (LPFP) software update for the Golf R, S3 and TT-S!
The APR Stage 3 GTX Turbocharger System for the MK6 Golf R, S3 and TT-S is the pinnacle of performance without compromise and APR is pleased to announce additional components and software designed to increase output even further.
Utilizing the APR Low Pressure Fuel Pump (LPFP), APR’s Calibration Experts were able to exploit mid range fueling headroom to add an additional 23 horsepower and 24 ft-lbs of torque. Expect even higher peak horsepower figures of 452 on 93 AKI fuel and up to 485 HP on race fuel. This directly translates into a more enjoyable driving experience with more power on tap across the entire RPM range.
Beyond dyno power figures alone, APR’s Calibration Experts refined several aspects of the calibration to provide a more enjoyable driving experience. Further refinements were made to ensure accelerative performance increased on top of the higher power figures. DSG equipped vehicles should notice crisp, fast shifts while manual transmission owners have the freedom to put forth their best abilities without the ECU numbing performance. Through each gear, the engine stays strong, and delivers blistering acceleration sure to put a smile on the driver’s face.
The software is available in 91 AKI / 95 RON, 93 AKI / 98 RON and 100 AKI / 104 RON fuel variants with a higher range of refinement and adaptability to the quality of each fuel. This helps to ensure the calibration remains safe, while also not leaving valuable horsepower behind when higher quality fuel is utilized.
The software update is offered for free to existing APR Stage 3 GTX customers who have purchased and installed the APR LPFP.
APR Stage 3 GTX Turbocharger System product page:
http://www.goapr.com/products/stage3...ea113_awd.html
APR LPFP product page:
http://www.goapr.com/products/lpfp_20t.html
MK2 TT owners, if we didn't have APR, LLC. software before for you, we do now. Contact us to schedule an appointment.
2013+ Audi TT 2.0 TFSI ECUs Now Supported!
APR is pleased to announce previously unsupported 2013+ model year Audi TT 2.0 TFSI ECUs now support APR’s DirectPort Programming.
DirectPort Programming enables the TT’s ECU to be flashed through the OBDII port without removing and opening the case. This also opens the TT to APR’s line of performance software and hardware from APR Stage 1 ECU upgrades all the way up to APR’s K04 Turbocharger System!
To read more about APR’s product line for the TT, please visit our TT product selection page:
http://www.goapr.com/products/?vehicle=TT_MKII
APR, LLC. has officially released the B8.5 and C7 A6 2.0T software. While we here at Excelerate Performance have already flashed a few B8.5s before the official release we're glad to see that it is now available for everyone. Contact us to flash your ECU directly through the OBD Port!!!
APR is pleased to present the ultimate engine control unit (ECU) upgrade for the 2.0 TFSI engine with Audi Valve lift as found in the B8.5 A4, A5, Allroad & Q5, C7 A6 and Exeo! APR’s ECU upgrade is available in octane-specific variations and is conveniently flashed to the vehicle’s factory ECU through the OBD-II port without any physical modification to the factory ECU. APR’s patented EMCS functionality puts the control of your engine’s operation at your fingertips and allows for additional features and options to be installed to your OEM ECU.
The APR Stage I ECU Upgrade is designed to work without requiring other changes to the vehicle’s hardware. With the ECU Upgrade alone, APR’s Calibration Experts measured higher peak figures of 284 horsepower and with 334 ft-lbs of torque 93 AKI octane fuel. Large gains were seen throughout the power band, including an additional 57 horsepower and 85 ft-lbs of torque. By adding E85 to the tank on the Ethanol compatible variants, automatic Ethanol map blending adds even more power, resulting in 85 horsepower and 135 ft-lbs of torque. The increase in power directly translates to an exceptionally quicker and more enjoyable vehicle.
Read More:
http://www.goapr.com/products/ecu_up..._long_b85.html
  #49
B7 S4 4.2 in for a Milltek Sport exhaust system
Old Jan 16, 2015 | 10:51 AM
  #50
Another innovative product released by APR, LLC. We will put some on order shortly and have these in stock for our customers and dealers.
APR Presents the 1.8T/2.0T Turbo Muffler Delete!
Designed for the new Golf/A3/Leon/Octavia 1.8T & 2.0T and the Audi A4/A4/A5/Q5 2.0T, the APR Turbo Muffler Delete replaces the factory muffler with a straight, uninterrupted piece, CNC-machined from billet aluminum and anodized black. To ensure proper sealing, APR’s engineers took a two-part approach. A Viton seal is included and forms a seal between the base of the muffler housing and the new piece. With the seal in place and the outer flange installed, the muffler delete tube screws into place, forming a full, uninterrupted path for airflow.
Read More:
http://www.goapr.com/products/turbo_...88_g3_ihi.html
Old Jan 16, 2015 | 10:55 AM
  #51
Another carbon cleaning today on an RS4, as well as a JHMotorsports Inc. intake manifold spacers and some additional important maintenance.
Old Jan 16, 2015 | 10:57 AM
  #52
Excelerate Performance is pleased to announce that we are now an Akrapovic Exhaust System distributor. For those of you first learning about Akrapovic, be prepared for the ultimate ride. With applications for Audi, VW, Porsche, BMW, Ferrari, Lamborghini, Mercedes and more, and technology that is extremely advanced we are excited to bring on this new partner. Keep an eye out for some installation images shortly.
http://www.akrapovic.com/
Every component of an Akrapovič exhaust is carefully designed and constructed by a highly skilled multidisciplinary team of designers, engineers and architects; they successfully take on daily challenges – combine a technical solution with an attractive, modern and state-of-the-art design.
Old Jan 16, 2015 | 11:00 AM
  #53
Excelerate Performance isn't strictly performance. We properly diagnose with top shelf electronic tools, repair them properly and timely, and maintain them to prevent future issues. Both of these APR, LLC. tuned MK6 vehicles are in for diagnostics and routine service.
Old Jan 16, 2015 | 11:07 AM
  #54
This pristine 2014 Porsche 991 Turbo S was in our shop for the highly anticipated AWE Tuning performance exhaust with diamond black quad tips.
With the old exhaust off, the turbos are exposed.
The new AWE Tuning exhaust is installed and we love the aggressive look, exhaust note, and increased performance, which is a far cry from the stock system.
We love the angle the AWE Tuning diamond black quad tips have exiting the car.
  #55
Milltek Sport has released their D4 S8 4.0T exhaust system and they will be arriving in the US in just a few weeks. Contact us for special introductory pricing.
We've just released our brand new Audi S8 4.0 TFSI exhaust system!
Full details at
http://www.millteksport.com/product....?articleid=156
Featuring Quad Cerakote Ceramic Coatings Black GT80 Tips
Lightweight Titanium Tips
Old Jan 16, 2015 | 11:09 AM
  #56
Speaking of Milltek Sport exhaust systems, we just installed one of their Sport cat back systems on this Audi Q7! Be sure to watch the before and after video.
This thing sounds beautiful!
Old Jan 16, 2015 | 11:10 AM
  #57
One of the many RS4s that have come in for service work and performance upgrades recently. This particular RS4 is getting a carbon cleaning, Milltek Sport catless downpipes, as well as JHMotorsports Inc. intake manifold spacers, 034Motorsport linkage arms, and JHM software.
Old Jan 16, 2015 | 11:11 AM
  #58
This B7 RS4 came all the way from Canada for carbon cleaning, a Forge Motorsport oil cooler setup, StopTech 2 piece zinc coated slotted Aero Rotors as well as important maintenance services.
  #59
This '08 B7 A4 came in for a Milltek Sport catback exhaust, along with some important maintenance work.
Old Jan 16, 2015 | 11:12 AM
  #60
Finally approaching completion, this B7 S4 came in for the works. VF Engineering supercharger kit, South Bend Clutch clutch kit, Bilstein and H&R Special Springs, LP. suspension, Billy Boat Performance Exhaust downpipes, StopTech brakes, timing chains with JHMotorsports Inc. tensioners, and even more.
The VF Engineering supercharger kit we installed on this B7 S4 on full display.
