Excelerate Performance: Northeast Audi & VW Performance and Service Center
Old Jan 16, 2015 | 12:05 PM
  #106
ExcelerateRep's Avatar
ExcelerateRep is infamous around these parts
Remember, we do not require an appointment for direct port flashing of APR software. A customer of ours came in today after loving his B8 A4 2.0T so much to get flashed with APR, LLC on his C7 A7 3.0T. Enjoy the new found power, we appreciate the business and hope to see you soon for you pulley upgrade!
Greg @ Excelerate Performance
Old Jan 16, 2015 | 02:24 PM
  #107
For those of you who aren't aware of the carbon build up issues that these direct injection cars, here is a little inside look. Build up like this can be a flow restriction leading to reduced performance and economy and can even cause a misfire if the conditions are right. This is a service performance quite often here at Excelerate Performance. If you are unsure if this has ever been performed on your vehicle, please call us to schedule an appointment.
The Start to the service
In Process...
The end result: Valves and intake paths that now look like new.
Old Jan 19, 2015 | 11:25 AM
  #108
A customer of ours came to Excelerate Performance to pick up his Sprint Blue B7 RS4, and dropped off his APR, LLC Stage 3 equipped Misano Red TT RS for some suspension modifications. Stay tuned for more of this beauty!
Old Jan 19, 2015 | 02:32 PM
  #109
A customer brought his B7 S4 Convertible to Excelerate Performance after receiving a fresh engine from Audi to get an APR, LLC. Carbonio intake installed and realign his Milltek Sport exhaust.
Old Jan 20, 2015 | 11:08 AM
  #110
Continuing on the Red B7 RS4:
The motor is back together, the transmission is finished, and everything is in position and ready to go back into the car. No corners are cut at Excelerate Performance. By making sure each bolt and mating surface is cleaned thoroughly, this eliminates any chance of oil leaks after the car is back together.
Next up: A B7 A4 2.0T in for some performance upgrades. This customer opted for the JHM front mount intercooler kit and high flow cat.
Old Jan 20, 2015 | 11:52 AM
  #111
A little bit of History was dropped off for some service this morning. With all the new model cars we see come through the shop, seeing this rare Europa Blue 95.5 URS6 Avant was a breath of fresh air! Fresh synthetic oil and new filter will keep this Precision Turbo & Engine 5858 and AAN 5 cylinder healthy for years and miles to come.
Old Jan 21, 2015 | 12:45 PM
  #112
Have you have been following photos posted of the B7 RS4 motor? Well here is more eye candy for you. In all its glory, here it is together and ready to go back into the car. Being tested with our Snap on Bluepoint smoke machine. It's all sealed with no leaks, its time to lower the lift and bolt the motor into the chassis.
Closing in on completion, the engine is back in, and its all final assembly from here. Stay tuned to see more as this job nears the finish line.
Old Jan 22, 2015 | 07:53 AM
  #113
One of our customers is back for some additional upgrades to his Silver B8 S4. This time, an AWE Tuning Track Exhaust! With the smile that was on his face when he left, I'm sure we will be seeing him again soon for a pulley and software re-flash. []
Old Jan 23, 2015 | 12:36 PM
  #114
Installing some brand new Michelin Pilot Super Sport Tires on the B7 RS4 that has been in the shop.
Old Jan 26, 2015 | 11:21 AM
  #115
The RS4 is finally up and running under its own power. It is also sporting a set of brand New Michelin Pilot Super Sport tires!
Old Jan 28, 2015 | 10:14 AM
  #116
Safety is a huge concern at Excelerate Performance. We always recommend inspecting your vehicle often to prevent failures that can result in injury. These tires shown here are worn down to their metal bands.If you don't feel comfortable performing this yourself, be sure to bring it to us.
Old Feb 3, 2015 | 03:54 PM
  #117
A 2009 CC 2.0T is in for what seemed like everlasting transmission issues, until now at least!
The customer has had trouble with this transmission since the car was only a few thousand miles old. We had the liberty of pulling out the transmission here at Excelerate Performance for further inspection. Without splitting the case in two our mechanic measured the end play on the input shaft, which is where it became interesting. There was far too much end play on the input shaft, not normal! So he took it a step further with a complete tear down to see if there was anything else causing the issue. With that being said we couldn't find anything wrong with the internal components of the transmission. Turns out the transmission was improperly assembled from the factory where the halves were not properly aligned.
Old Feb 5, 2015 | 11:44 AM
  #118
This A3 sporting a 2.0T FSi engine came in for a laundry list of service work. The car also suffered from a single cylinder misfire. By performing proper diagnostics, our mechanics were able to fix the real underlying issue rather than throw parts at it. Here is a side by side comparison of the fuel injector that was causing the misfire.
Old Feb 5, 2015 | 02:53 PM
  #119
This '02 Allroad 2.7T is in for an automatic transmission service and diagnostics today.
Old Feb 6, 2015 | 10:48 AM
  #120
This MK6 GLI came to us for a DieselGeek Short Shifter and APR Stage 2 Intake performance upgrades as well as some service love with a fresh synthetic oil change.
