Other Japanese Supercars Toyota Supra, Honda NSX, Mazda RX-7 etc.
Mitsubishi EVO Intake Kits
Old Mar 8, 2011 | 03:36 PM
Agency Power's Avatar
Platinum Sponsor
Agency Power is just really niceAgency Power is just really niceAgency Power is just really niceAgency Power is just really nice
AGENCY POWER EVO INTAKE SYSTEMS!
Turbocharged vehicles require a couple of simple bolt on modifications to really open up their power and give that engine a great sound. The first most popular product is an intake kit. Agency Power has engineered and tested to release this short ram intake system for the all new 2008 and up Mitsubishi EVO X(ALSO AVAILABLE FOR OLDER EVO MODELS, CLICK HERE).
The short ram intake features an aluminum intake pipe with a CNC machined aluminum MAF sensor adapter. The factory MAF sensor fits securely into place with provided hardware. To keep cool air directed to the intake system, AP has retained the factory air inlet scoop similar to the OEM air box. The air scoop snaps into place on our aluminum heat shield like factory.
There is no cutting or altering your OEM components. The heat shield is designed to keep cool air going into the intake system. Using the factory rubber grommets and mounting positions, the heat shield will drop into place for a secure fit. AP uses high quality cone air filters for this EVO X intake system. The air filter features a 3 inch front funnel style inlet which is perfect for the direct air flow coming from the front of the car. The filter fits on to the 3 inch intake pipe with a simple worm clamp. The intake pipe diameter is increased to 3.25 inch on one side to fit the factory rubber suction pipe. It can also be used with our aftermarket suction pipe using an AP silicone coupler to connect the two.
By freeing up the air flow, the intake will give your car faster throttle response, increased turbo sound, and as tested on a Mustang AWD Dyno, add approximately 20 Horsepower and 16 Ft/Lbs of Torque. The Mitsubishi EVO X intakes are available in a gloss red or polished finish. Also available with a Red or Blue K&N Filter. The heat shield boxes are powder coated in textured black which also feature our Agency Power badge. This intake will fit all the 2008 and up Mitsubishi EVO X turbo charged cars.
All Agency Power products feature a limited lifetime warranty.
Jul 29, 2019 11:13 AM
tkebp1275
Aug 31, 2015 06:35 PM
TrackOne
Aug 20, 2015 12:56 PM
Wheel Experts
American Muscle
Aug 19, 2015 09:07 AM
Wheel Experts
Wheels/Tires
Aug 19, 2015 09:05 AM
