Other Japanese Supercars Toyota Supra, Honda NSX, Mazda RX-7 etc.
08 350z build
Old Feb 19, 2012 | 10:32 PM
  #31
Robert_K's Avatar
Robert_K is infamous around these parts
Originally Posted by ace32x
lol same set up as my DE down to the compression haha, what a coincidence
Well I wanted the Cosworth 8.8:1 pistons but they phased them out.
Old Feb 19, 2012 | 10:48 PM
  #32
ace32x's Avatar
ace32x is infamous around these parts
yea
Old Feb 20, 2012 | 08:13 AM
  #33
RoadRunnerSTi's Avatar
RoadRunnerSTi is infamous around these parts
When do you go to the track to see if the trap speeds match the whp #s??
Old Feb 20, 2012 | 09:18 AM
  #34
ace32x's Avatar
soon as the weather gets better out here, its still 35-40 and raining. probably aprilish or may itl be nice enough to get a few good runs in. im not caged so i only get one crack at it so im trying to make it a good onexD
Old Feb 20, 2012 | 09:20 AM
  #35
ace32x's Avatar
blew the headgasket aswell so have to rebuild the motor this coming week. swapping injectors to id1000s doing some jwtc1hr cams springs and retainers and looking into rebuilding my current gt2871's with the need billet compressor and turbine wheels or going up to a gtx 3076. and removing the water meth system while its apart. causing unnecessary headaches
Old Feb 20, 2012 | 09:25 AM
  #36
Robert_K's Avatar
Surprised you haven't started with a lot of the above mentioned. Here is my Z; https://www.6speedonline.com/forums/...-Robert_K.html
  #37
ENV²'s Avatar
ENV² is a jewel in the roughENV² is a jewel in the roughENV² is a jewel in the rough
I loved my 350Z... Shouldve kept it and built it!!! ARGHHH!
Ill get another one someday and do this
Old Feb 20, 2012 | 09:30 AM
  #38
ace32x's Avatar
i have a built one im selling for cheap
Old Feb 20, 2012 | 09:32 AM
  #39
ace32x's Avatar
was running low on cash when we put it back together last time and the stock HR cams have more lift that the DE's and supported my flow goals of 700. so i didnt do the cams or anything since the turbos would only support that much and my 850 DW injectors were fine for that.
got a little more money now so beefing it up a little more while its apart
Old Feb 20, 2012 | 09:36 AM
  #40
Robert_K's Avatar
Gotcha!
Old Feb 20, 2012 | 12:32 PM
  #41
Do you know why the head gasket popped?
Old Feb 20, 2012 | 12:35 PM
  #42
ace32x's Avatar
not yet, not even positive thats what happened. But there is definetly air getting in the cooling system when the car is under load. Motor is coming out this week and were going to find the culprit. headgasket just seems the most likely at this point
Old Mar 16, 2012 | 10:51 AM
  #43
ace32x's Avatar
update, blew the headgasket. have new ones on order aswell as some other goodies. decided to ditch the watermeth, and upgrading to twin gt 3076r's with.86 AR. all this will be in first thing on next week and everything will start going back together.
Old Mar 16, 2012 | 02:30 PM
  #44
So do you know what cause the head gasket or gaskets to fail?
Old Mar 16, 2012 | 03:06 PM
  #45
ace32x's Avatar
my guess is improper deck of the heads first time around. none of the headstuds stretched, sleeves didnt drop. so thats what were left with. redecked them and hoping for the best xD
