Other Japanese Supercars Toyota Supra, Honda NSX, Mazda RX-7 etc.
Titan Motorsports Brake Master Cylinder Kit
Old Dec 11, 2017 | 10:59 AM
titannero's Avatar
titannero is just really nicetitannero is just really nicetitannero is just really nicetitannero is just really nicetitannero is just really nice
The Titan Motorsports clutch master cylinder upgrade kit facilitates the bolt-in upgrade to a race-grade Tilton master for the 1993-1998 Toyota Supra. The Tilton master cylinder kit is designed with racing clutches in mind and offers a larger bore size than the factory 5/8” unit which gives the driver a more consistent pedal feel through the entire range of travel.
This kit is offered with your choice of 2 compatible Tilton Master cylinder kits in either ¾” or 7/10” bore size. We typically recommend the ¾” for Tilton clutch kits or factory style single disk clutches without a heavy pressure plate. The 7/10” bore size is a great option for those with multi-disc or clutches with a heavier pressure plate. This kit is a completely bolt on affair that requires no custom fabrication and can be removed and returned to stock at any time.
Kit Includes:
• Billet Firewall Adapter
• Tilton Master Cylinder (in ¾” or 7/10” bore size)
• Tilton Reservoir
• Clutch Fork Retrofit /stock style attachment to pedal
• All Hardware for Installation
Available Now:
http://www.titanmotorsports.com/tita...r-upgrade.html
Turbo Fanatic
Feb 28, 2013 12:28 PM
titannero
Nissan GTR
Nov 28, 2012 01:10 PM
heavychevy
Feb 6, 2010 03:20 PM
