997 Turbo, GT3, GT3 RS Brake Master Cylinder?
Does anyone know if these are a different part number?
I'm running 997 Turbo Brakes all around and the rear calipers require more fluid resulting in a bit more initial pedal travel than I'd like. Otherwise, these brakes are great! Much more fade resistant (very similar to 9996 GT3 front setup with even bigger 4 post rears). Anyone know if any of the 997 master cylinders can be retrofitted to the 996? Even a small change in piston size will make a big difference in pedal feel.
Are you sure that there is no air in the system and that the fluid is topped off? Reason I am asking is I upgraded to the 996GT3 brake system, front and rear. After installation I had long pedal travel. My tech re-bled the brakes and the pedal travel was the same as before the upgrade. You may be right that the 997TT brakes need more fluid, I don't have the knowledge to tell you that. Just thought I'd give you something else to consider.
The 996 GT3 has a 6piston fronts and 4 piston rears. The 997 Turbo uses almost identical 6 pot calipers up front but had larger 4 pot pistons acting on 350mm rotors. The REAR brakes (for the 997TT) in my setup require more fluid compared to any factory 996 setup.
I will however have my tech bleed the system.
I have GT3 6-piston brakes up front. It would be great to have some type of master cylinder upgrade w/o extensive modifications.
It's very easy. Swap to the 997 GT3 master..
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
PelicanParts.com
997 Vendor Classifieds
Aug 18, 2015 03:39 PM
