Battery Maintainer
Old May 15, 2010 | 07:09 AM
rich_daystrom's Avatar
rich_daystrom is infamous around these parts
Battery Maintainer
Anyone use a battery maintainer on a Panamera? Since the battery is under the passenger seat, it's not directly accessible like a 911. Would you connect to the jumper terminals in the engine compartment, or use the lighter plug? I would rather use my Deltran Battery Tender than buy the Porsche lighter charger, but not sure if connecting to the jumper terminals could affect the system electronics.
Old May 15, 2010 | 10:46 AM
DBV's Avatar
DBV
DBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud of
Thumbs up
Using the Deltran on the jumper terminals should be fine. No need to get the Porsche tender, even though it does make things a lot more convenient. FYI I had this information confirmed by a Porsche Tech.
Old May 16, 2010 | 04:09 PM
dan993's Avatar
dan993 is infamous around these parts
Technical manual specifically notes that charger or jumper leads should only be connected directly in the engine compartment. If connected to the battery, the battery sensor may be damaged, and incorrect information is sent to the gateway.
Old May 17, 2010 | 04:47 PM
Root's Avatar
Root is a glorious beacon of lightRoot is a glorious beacon of lightRoot is a glorious beacon of lightRoot is a glorious beacon of lightRoot is a glorious beacon of light
I have used the dual mode Porsche charger several times on the Panny and it works fine.
996_717
Jan 27, 2022 04:04 AM
laz74
Oct 2, 2015 06:08 AM
gadgetman
Sep 10, 2015 03:29 PM
katyrow
Sep 7, 2015 10:17 AM
