What octane gas for V6?
Old Oct 19, 2012 | 12:44 AM
rzundel's Avatar
rzundel is infamous around these parts
What Octane gas are you guys running in your V6 Panamera? Hard to believe this car need premium gas with 91 octane.
Old Oct 19, 2012 | 05:47 PM
teutonic GT2's Avatar
teutonic GT2 is infamous around these parts
Really??
You buy a Panamera and try to cheap out on gas?
Read the manual ...
Old Oct 19, 2012 | 11:33 PM
rzundel's Avatar
Originally Posted by teutonic GT2
Really??
Read the manual ...
Where's your manners? You have no idea who I am and btw far from cheap. Hold your opinion if you don't have anything smart to offer. This is a V6 motor. Every motor is tuned to a certain octane. The manual actually says 93 octane so that tells me nothing. Premium in California is 91. I question if the manual was even written/updated for the V6 version of the car? I am asking this question to other V6 owners of the car to see what octane you are running?
Old Oct 20, 2012 | 12:09 AM
phil612's Avatar
phil612 is infamous around these parts
It's basically the same engine as the V8 but with two less cylinders, how does that make it any less sensitive to low octane? I'd agree with rzundel, why would you want to use cheap gas in the Panamera? Sounds like you've read the manual, my advice would be stick to it.
Old Oct 20, 2012 | 12:33 PM
ICE's Avatar
ICE
ICE is infamous around these parts
i run min 91 but try to run 94
Old Oct 20, 2012 | 12:36 PM
Left Hander's Avatar
Left Hander is infamous around these parts
91 would probably be ok but for the small difference in price 93 is probably a better bet. I have just used 93 in the porsches I've had/have (cayman s, boxster s, cayenne).
A friend uses a mix of 91/93 in his cayenne fwiw.
Old Oct 20, 2012 | 02:59 PM
RobertM's Avatar
RobertM is a glorious beacon of lightRobertM is a glorious beacon of lightRobertM is a glorious beacon of lightRobertM is a glorious beacon of lightRobertM is a glorious beacon of light
when I had my v6 panamera, I used regular unleaded and never had an issue. I have a couple of friends that have a degree in fluid engineering and they both stated that there is no issue with using regular vs 91 or higher and both use it in their range rover sc_hse.
I also have a mercedes s550 and when I put regular in the the engine light would come on. So 93 or higher in that car . . . . .
try it and see if it makes a difference . . . .
I also noticed that when using 93 or greater, I did get better gas mileage.
Old Oct 20, 2012 | 03:28 PM
kip's Avatar
kip
kip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to behold
This is more important in turbo engines were lower octane gas tends to combust prematurely. I always use highest octane available for the longevity of the engine.
Old Oct 20, 2012 | 03:46 PM
rzundel's Avatar
I'm not even sure where you get 93 octane gas here in Southern California? The highest I've seen is 91.
Old Oct 20, 2012 | 08:13 PM
TGED's Avatar
TGED is infamous around these parts
I use 94 octane in Toronto.
Old Oct 21, 2012 | 11:43 AM
keeperofbeasts's Avatar
keeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond repute
Stick with 91...it's good enough
White991TT
Mar 8, 2016 06:01 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
whtrabt
Oct 5, 2015 05:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
TOGWT
Detailing
Oct 1, 2015 07:59 AM
