How to Change Plate Lights?
Old May 27, 2013 | 05:33 PM
kw911TT's Avatar
kw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud of
Need some help here from people who have change out the license plate lights. I cannot get the housing to move. Follow the manual to insert the flat screwdriver into the left hole, pushed it left, right, up and down pretty hard; the housing didn’t move a bit. I’ve already changed the Cayenne and 911, they were quite easy to do. Any trick on the Panamera?
Old May 28, 2013 | 02:13 AM
TGED's Avatar
TGED is infamous around these parts
I just did mine. Do not pry through the slot, pry at the outside edge next to the slot, wrap a piece of cloth on a flat blade screw driver, the first one took a while, but the second was really easy, now I can pop one out in seconds.
Old May 28, 2013 | 08:22 AM
kw911TT's Avatar
Thanks TGED, the manual show to insert the screwdriver into the slot, but you pry on the outside of the black housing?
Old May 28, 2013 | 01:32 PM
SoCalPamTurbo's Avatar
SoCalPamTurbo is a splendid one to beholdSoCalPamTurbo is a splendid one to beholdSoCalPamTurbo is a splendid one to beholdSoCalPamTurbo is a splendid one to beholdSoCalPamTurbo is a splendid one to beholdSoCalPamTurbo is a splendid one to behold
I did the same as TGED. It took me 2 flat head screw drivers to get the housing open. One from the side of the housing and into the hole. Be careful, I almost broke the plastic.
Old May 28, 2013 | 03:38 PM
TGED's Avatar
I only needed one screw driver. Just pry from the edge of the housing, and pry hard, it won't break that easily. Now I am able to repeatedly pop the housing out in seconds. Since the Suncoast LEDs bulbs gave me error codes, I needed to swap different bulbs to do some testing.
Old May 28, 2013 | 10:11 PM
kw911TT's Avatar
It worked!
Thank you
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
00aston
Aug 27, 2015 12:01 AM
TrackOne
Aug 20, 2015 12:56 PM
