Help - Clunking noise after installing H&R springs
Old Oct 21, 2013 | 10:00 PM
rzundel's Avatar
rzundel is infamous around these parts
I had H&R springs installed and love the look and ride. Problem is when I go over speed bumps I hear a clanking noise coming from the rear. Seems like something like the exhaust or something else is hitting something with the lower clearance. Anyone else have this problem and figure out what the problem was?
Old Oct 23, 2013 | 11:40 AM
tom kerr's Avatar
that can happen with those springs just due to normal compression and expansion. IIRC there was a "fix" for this for the 911's would ask shop about that
if they dont know I will ask my crew chief
Old Oct 23, 2013 | 11:42 PM
rzundel's Avatar
Thanks Tom. I don't think it is spring compression. What it sounds like is that because the ride height is lower that something from the undercarriage is hitting against something. Only happens when I go over spread bumps at a slow speed. You hear a clanking noise in the rear. Sometime, not all the time.
Old Oct 24, 2013 | 07:10 PM
tom kerr's Avatar
Sorry to hear but had a similar thing with my 996 and was corrected
Good luck !!
Old Oct 25, 2013 | 07:52 PM
benblack's Avatar
benblack is a jewel in the roughbenblack is a jewel in the roughbenblack is a jewel in the rough
is it just bottoming out in the rear when u go over the bump?
Old Oct 25, 2013 | 11:29 PM
rzundel's Avatar
Don't know. Very well could be. The car is lowered 1.5". Only happens over speed bumps. That is why I wanted to see if others were experiencing something similar?
Old Oct 26, 2013 | 12:54 PM
2thDoctor's Avatar
2thDoctor is infamous around these parts
Is your front wheel gap just a little larger than the rear?
Old Oct 26, 2013 | 01:03 PM
rzundel's Avatar
Yes, the rear sits a just little lower. About 1/4".
Old Oct 26, 2013 | 03:15 PM
2thDoctor's Avatar
That's weird. I would have thought the front would be lower....
Old Oct 26, 2013 | 03:49 PM
rzundel's Avatar
I would agree. Do you have V6 or V8? The only logic I can come up with is that the V8 is about 400lbs heavier in front and the springs might have been built to spec on the V8.
Old Oct 26, 2013 | 05:05 PM
2thDoctor's Avatar
V6 unfortunately....
Old Oct 26, 2013 | 05:56 PM
rzundel's Avatar
As a daily driver I love the V6. No shame there.
Old Oct 26, 2013 | 05:59 PM
rzundel's Avatar
I had some time today and put my Panamera up on my lift. I thoroughly inspected the suspension area and can see no where the bottom out clank noise is coming from. Hmmm. Maybe just one of those things I will have to live with. Doesn't happen too often.
Old Oct 27, 2013 | 11:38 AM
supercup's Avatar
supercup is infamous around these parts
Do you have sway bars on your car? If so your sway bars may be hitting the suspension links when the suspension compresses, as you don't have proper clearance with the lowered springs. This happened to me on my 2001 Turbo with I installed Tech Art coilover's, but stayed with stock sway bars - clunked when suspension compressed. We could see no place where things were hitting. After much trial and error we changed out to Tech Art Adj. sway bars and the issue was solved.
May not apply to Panny but good luck.
John
Old Nov 8, 2013 | 08:31 PM
kasimmmmm's Avatar
kasimmmmm is infamous around these parts
i have H&R springs too and have no issues. Car drives like stock. Sounds like a bad install job and springs are probably not sitting correctly.
