Help resetting TPM after installing 22" wheels
Old Nov 3, 2013 | 07:45 PM
rzundel's Avatar
rzundel is infamous around these parts
I just installed new 22" wheels and used my factory TPM sensors. I was told that the car would automatically reset and read the sensors. This is not the case. The TPM warning light stays on. Is there a way to reset this? I read the owners manual and couldn't find anything that helped. For someone that has changed wheels please advise? Thanks
Old Nov 3, 2013 | 09:14 PM
tlis300's Avatar
tlis300 has a spectacular aura abouttlis300 has a spectacular aura about
You need to go into your PCM and put in learning mode. Drive around for about 30 minutes and you should be good to go. If that doesn't work, the battary may be dead. There is a tool most tires shop have that can check the battary. Good luck!
Old Nov 3, 2013 | 09:54 PM
rzundel's Avatar
Can you please tell me how I get into the PCM to put in learning mode? The battery should be good with the TPMs because the car is only a year old.
Old Nov 4, 2013 | 08:29 AM
tlis300's Avatar
You can access it through the PCM or you can toggle through it from you instrument panel. Go into the menu screen and flip through it until you see TPS. Follow the instructions and then drive around for 30 minutes. The info can also be found in your owners manual . Hope that helps.
Old Nov 4, 2013 | 10:51 PM
rzundel's Avatar
Went to the dealer today and they changed the wheel setting to something other than what it was sent on (there is not 22 as an option) and it put it into learning mode and fixed the problem. Thx for everyone's help.
no1joey
Sep 2, 2015 12:32 AM
Aug 21, 2015 09:56 AM
MAcarbon
Aug 19, 2015 04:52 PM
