custom tune vs "box" tune on turbo
Old Feb 9, 2014 | 07:44 AM
TXTurbo's Avatar
TXTurbo is just really niceTXTurbo is just really niceTXTurbo is just really niceTXTurbo is just really nice
It seems that the tuners have what I would call "Box" tunes for turbos.
When a tune is developed how many cars is the tune optimized across?
How much is potentially left on the table to allow the tune to work with all cars in all environments, altitude, temp and humidity?
Old Feb 9, 2014 | 10:02 AM
KICKINIT's Avatar
KICKINIT is infamous around these parts
I've asked this before as well without an answer.
What's the difference from the new Vivid racing bench tunes vs
GIAC tune????
Which tune makes more power
Old Feb 9, 2014 | 04:15 PM
SRT10Venomous's Avatar
SRT10Venomous is a glorious beacon of lightSRT10Venomous is a glorious beacon of lightSRT10Venomous is a glorious beacon of lightSRT10Venomous is a glorious beacon of lightSRT10Venomous is a glorious beacon of light
A ton remains your car vs another car can have major differences. Boxed tunes are not recommended especially for turbo.
Old Feb 10, 2014 | 09:06 AM
KICKINIT's Avatar
Any of the companies who do tunes care to chime in on this topic.
Old Feb 10, 2014 | 03:36 PM
TSTARKZ123's Avatar
TSTARKZ123 is infamous around these parts
I respectfully disagree. Realize the advancement of the Bosch Motronic ECUs in our cars. They adjust for weather compensation, monitor wideband air/fuel ratios, monitor timing advancement vs knock tables; all while making slight adjustments on its own. It's not like the tune is "locked" into a specific setting. There are adjustments done constantly by the "boxed" tune and ECU.
Old Feb 10, 2014 | 03:50 PM
Undercover Tuning's Avatar
Undercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond repute
sadly there are only a handful of companies even offering tuning for the panamera chassis, most "claim" certain numbers however sadly not many show true dyno testing videos nor dyno graphs to back the numbers leaving us all to wonder what really is being made.
most for the turbo models are showing 80+ hp gains which is substantial and very noticeable when driving from a stand still punch to 60, and on the highway roll pulls done from 60mph-130mph.
there is a difference between "custom" tuning and just a standard bench flash as they call them now a days. custom tuning is specific to your car and the parts/upgrades done on your vehical and most shops and companies don't or cant do this thru the factory ecu, providing a another market called "stand alone engine management' such as motec,aem,haltec,pro efi in which a "custom" tuner can go in and change engine parameters using mechanical knowledge as well as computer knowledge to properly adjust settings such as timing,sensor control,fuel,air to fuel,mass air flow etc to your vehicles needs achieving even higher gains then standard "piggy back or bench flashing"
contact us for tuning solutions and stand alone ems system installs and tuning for all vehicles as well as best pricing on currently offered tunes!
undercoverperformanceinc@gmail.com
856-382-7543
Old Feb 11, 2014 | 02:34 AM
TXTurbo's Avatar
I suspect that putting in a stand alone engine managment system is all but impossible.
Still waiting for one of the Pamamera or Cayenne box tuners to chime in. EVO.. GAIC.. Techart..???
Old Feb 11, 2014 | 01:37 PM
KICKINIT's Avatar
Kind of strange none of them seem to reply to this in an open forum
Old Feb 11, 2014 | 05:21 PM
elsupremo's Avatar
elsupremo is infamous around these parts
Well, it's pretty certain that a custom tune is going to perform better than a generic one (assuming the tuner knows what they're doing). I know Cobb Tuning is working on an access port to do just that.
Would love to see more dynos before/after these all these tunes. Pretty much the only way of knowing whether the hype is true or not.
Old Feb 14, 2014 | 12:21 PM
Andrew@GIAC's Avatar
Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !
We're actually not allowed to post in public forums regarding our software with actual data because the moderators will delete it. All I can say is that we've tested our software back to back against a piggyback tuner with AWE Tuning and the results were heavily in our favor.
Old Feb 14, 2014 | 12:25 PM
You're somewhat mistaken. If you're going to be adding a large number of custom hardware upgrades to the car (larger turbochargers, etc..), then you can take advantage of something more custom to suite the higher output potential. However, if you're doing a secondary cat delete, IPD plenum upgrade and an exhaust, you're not going to make anymore power on these cars than we do without doing some very irresponsible things to the DME in an effort to force the power up (such as reducing knock sensor sensitivity). These cars are heavily adaptive with a myriad of timing maps to choose from. We set the boost at a level (with stock primary cats) where the EGTs are in a safe, reliable range.
BlackMarketRacing
Dec 3, 2015 10:46 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
PenguiN
Sep 15, 2015 11:44 AM
Aug 19, 2015 06:55 PM
