P4s unbelievable handling. However need advise
Old Mar 7, 2014 | 10:32 AM
DNICE357's Avatar
DNICE357 is infamous around these parts
Originally Posted by nick.kapoor
That's how I feel too. If I am cruising, its an ok drive. As a matter of fact there are more comfortable cars out there, I currently own or have owned. However, the p4s gives you a feeling that is hard to express especially when you are pushing it around corners: the car feels very "planted" and you can take sharper turns at a relatively faster speed without being unsure if you will slide or not. However, some of us do like to slide it and if you do, the slide is very controllable.
I have a '10 S and I have to agree with you regarding the ride at cruising speed. Albeit, the ride is not bad at all, other cars I have owned and own are better in terms of overall noise level and comfort. However, none can compare to the what the Panny was made to do, and that is perform at high speeds with control. I researched a ton before I bought my S even between the two models S & 4S, (couldn't swing the extra chips for the Turbo), and I'm very happy with my S. I do wish the backup camera was standard, because the 360 warning system I have now is just not the same. But as far as the drive, I live in a rural area where there are many open, windy roads where I can open up my Panny. I've gone 100+ mph, on these roads and it's such a pleasure to know the Panny is just laughing at me because it knows it can handle it. All this just with the stock setup. I'm thinking about getting the ECU flashed and adding a cold air intake, but I'm still doing research on this. I'm at 400 bhp and would like to get to 450 bhp, with some additional low end torque. But, trust me if I left it all as stock I'm cool with the performance. Even better when you do all of this with two sets of golf clubs in the back
Old Mar 7, 2014 | 05:54 PM
nick.kapoor's Avatar
nick.kapoor is infamous around these parts
360 warning system for p4s as oem
Was wondering if you can recommend any 360 warning systems and the one you bought, what you liked and didn't like. I am very interested in completing the options I currently have.
DNice: Also, once you have some conclusive research, would you be kind to share your findings related to the ECU flash? Many thanks.
Old Mar 8, 2014 | 04:16 AM
Originally Posted by 2010Panny4S
good question. I have a 2010 panny as well.
How to find out the version number: press INFO, OPTION, SYSTEM
Old Mar 11, 2014 | 05:54 PM
Apparently the tire pressure had a lot to do with the comfort and noise level. Reduced the tire pressure from 43psi to 32psi and the noise is gone. In case someone is having a similar issue and this maybe one of the things to check. Got the car cleaned and took some pics - now gotta figure out how to upload pics in 6.
Old Mar 11, 2014 | 06:03 PM
danyoP4S
Sep 30, 2021 05:06 AM
ECS Tuning - BMW
BMW Vendor Classifieds
Oct 28, 2015 10:48 AM
WEEED
Cayenne
Sep 25, 2015 10:45 PM
