Water not draining by gas tank filler neck
Old Mar 5, 2014 | 07:11 PM
jjdeakin's Avatar
jjdeakin is infamous around these parts
Water is not draining from the area around the gas filler neck. I have tried blowing compressed air in the hole. I was able to insert picture wire down the hole about one foot before it stops. I can't find where the water drains out of the car to the ground so I can check for a clog there. Can someone please tell me where the drain hole is underneath the car or another solutions for standing water not draining from the gas cap area. Thanks
Old Mar 6, 2014 | 06:35 AM
cvprez's Avatar
cvprez is infamous around these parts
I had the same problem on my 2010 and I can't tell you exactly where it drains, but the dealer replaced mine under warranty
Old Mar 6, 2014 | 07:09 AM
jjdeakin's Avatar
Thanks. Hopefully my dealer will do the same and fix under warranty
Old Mar 6, 2014 | 12:08 PM
DNICE357's Avatar
DNICE357 is infamous around these parts
Thumbs up
Interesting, I noticed this one time after I got my Panny washed and then stopped to fill up for gas. I just thought it was due to it just being washed. I took a paper towel and dried it up. Since I live in Cali, and we never get rain I haven't noticed this before or after. Looks like I'll keep an eye on this because I'm still under warranty. Thanks for the info.
Old Jun 5, 2019 | 03:09 PM
Randal T's Avatar
Randal T is infamous around these parts
Any update!?
Experiencing this now. Would love to know how to unclog the drain.
Old Jun 5, 2019 | 06:11 PM
stealthn's Avatar
stealthn is infamous around these parts
Never heard of one catching fire, would think there would be other types of recalls first
Old Jun 5, 2019 | 06:15 PM
Randal T's Avatar
Solved
I blew air using a compressor and it cleared the drain. Tested with some water and all good.
Old Aug 2, 2020 | 12:31 PM
newporsche's Avatar
5 Year Member
newporsche is infamous around these parts
hey all i notice this quite a few times too in my 2010 panamera, the hole below the gas filler neck has a small puddle of standing water. is this a big concern that i need to take care of right away? what is the best way to fix this?
thank you
Old Aug 2, 2020 | 03:39 PM
Randal T's Avatar
thank you
Probably not a huge concern, but more of annoyance.
If I remember correctly, I poked a hard wire in the whole to unclog it. I also may have blew compressed air.
It unclogged and is back to normal.
Old Aug 2, 2020 | 05:22 PM
Stringbag's Avatar
Stringbag is infamous around these parts
The tube runs behind the wheel arch liner and exits near the air suspension strut.
You need to remove the liner to get to it. Not difficult at all.
Old Jan 15, 2022 | 02:34 PM
newporsche's Avatar
5 Year Member
would a clothes hanger wire fit in to try to unclog?
Old Jan 17, 2022 | 01:02 PM
JPhi1618's Avatar
JPhi1618 is infamous around these parts
You're going to want something more flexible - a thinner wire. You want it to follow any curves of the tube and any clog should be pretty soft mold or gunk.
Old Jan 18, 2022 | 12:12 AM
newporsche's Avatar
5 Year Member
ya the clothes hanger didnt go too far in before i couldnt go any further, anything i could buy at a store that would work best ?
Old Jan 19, 2022 | 11:47 AM
Kirkman's Avatar
Kirkman is infamous around these parts
A better choice of "wire" to unplug a line is "nylon" weed-wacker-type cord.
Old Jan 25, 2022 | 10:52 PM
newporsche's Avatar
5 Year Member
any wire u recommend that is easily bought at a store?
