Rear climate control removal.. Help!
Old Mar 30, 2014 | 05:29 PM
Neostream's Avatar
Neostream is infamous around these parts
Hello, I need to change the rear right climate control module on a panamera, I donno how to disassemble the module from its place... Please help...
Old Apr 4, 2014 | 11:30 AM
Neostream's Avatar
Since nobody answered I tried to figure out how to disassemble it, first you have to pull up the grey plastic between the ducts , two clips , pull up the wooden part in between , four clips , you ll find eight screws , retaining the right and left modules and the ducts to the underlying frame, the tricky part is removing the ducts, each one is SWIVELLED to its side, and the right,left and the underlying board raises as a one unit, both modules are retained by engagement lips and a cable to the main middle board here are some pics, time to do the job less than ten minutes- I m a doctor by the way.
Old Apr 4, 2014 | 11:39 AM
CMLXX4S's Avatar
CMLXX4S is infamous around these parts
That's not something I'd consider doing myself.... I'm sure that has something to do w/ no one answering.
Old Apr 4, 2014 | 12:37 PM
Neostream's Avatar
Yes, I agree but the stealership asked for 2500$ to replace , I took it to a shop that fixes such boards, and a 10$ IC was the cause !!!! Paid the shop 50$ and it is working again... At more than one occasion with my three Porsches I found that what is wrong was something really tiny and doesn t justify replacing the whole system , but unfortunately the dealership won t fix, it replaces only
Anyways I am sharing my experience for the general benefit
Old Apr 5, 2014 | 04:33 AM
Yankee's Avatar
Yankee is infamous around these parts
Just saw this or I would have responded with how to. It is not difficult to do. I have removed the entire interior trim including seats, door panels, carpets etc. it is a pain and things break easily as in other P cars. Get a good trim removal tool kit and you should be good. Just make sure the removal tool is a flexible type and not rigid. HF has a good one. eBay orange kit is no good.
Make sure to seat back and torque the center panel or it will make noises.
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
orbelo
Aug 30, 2015 12:26 PM
Glasig
Aug 23, 2015 03:35 PM
TrackOne
Aug 20, 2015 12:56 PM
