KW suspension module for PTTS
Old Sep 8, 2014 | 08:25 PM
donutcritic's Avatar
donutcritic is infamous around these parts
Has anyone installed the KW (or H&R) suspension modules for their Airride equipped PTT? I have a MY14 PTTS with PASM/airride and am aiming to lower the normal ride height by 10-15mm to complement some HRE wheels which have a slightly wider stance than the OE 20" wheels.
Unfortunately my dealer received a "defective" KW unit and is now negotiating with KW to order a replacement. The KW module was causing airbag suspension errors. I'm hopeful someone here has prior experience with KW and a MY14 car and will tell me it's going to be ok -- I've been without my beast for 4 weeks and am beyond agitated at how long this process is taking.
Old Sep 8, 2014 | 09:51 PM
pandawest's Avatar
pandawest is infamous around these parts
I understand your frustration...but when its done please post some side view pics. I love the look of my car when PASM is lower in sport plus, its looks longer and oh so good.
Old Sep 9, 2014 | 05:05 AM
Pbread's Avatar
Pbread is infamous around these parts
I went with the lowering links vs the module... Low tech and very cost effective option that is fairly OEM in concept (just adjust the links that tell the sensor on air susp how low to lower it). Good luck however as it would be nice to be able to adjust height at will / on the fly... Let us know how it works out
Old Sep 9, 2014 | 06:14 AM
tonyep's Avatar
tonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of light
I am currently using the renntech lowering module on my PTT, been over a year and not a single error. It's the same as the KW without the wireless control. I can control the module using my android phone since they have an app for it. H&R module are not adjustable, it gives a fixed drop.
Old Sep 9, 2014 | 06:24 AM
Pbread's Avatar
Oh wow - didn't realize that... I thought the "control" was the value in the modules vs lowering links...
Old Sep 9, 2014 | 06:33 AM
Pbread's Avatar
By the way - my dealer installed the fvd lowering links in about an hour... Can adjust for a fixed drop with air suspension / sport mode up to 2" from regular sport mode height
Old Sep 9, 2014 | 10:46 AM
Pbread's Avatar
Couple of pics re: slammed panamera... This is the lowest the air suspension can go...
Old Sep 9, 2014 | 12:16 PM
2010Panny4S's Avatar
2010Panny4S is infamous around these parts
Damn P that's tuckin
Old Sep 9, 2014 | 05:35 PM
tonyep's Avatar
I went with links initially at first too but swapped them out for the module. Much more control vs having to go under the car every time you need adjust the height.
Old Sep 10, 2014 | 06:49 AM
Pbread's Avatar
Ya - that would be very sweet to adjust height from an app...
Old Sep 12, 2014 | 01:21 PM
iglambo's Avatar
iglambo is infamous around these parts
If you know how to use PIWIS tester you can lower the car with no additional units. I did it myself.
Old Sep 12, 2014 | 01:26 PM
Pbread's Avatar
Very cool - I've always wondered if this could be done...
Old Sep 16, 2014 | 07:23 PM
frozen997's Avatar
frozen997 is infamous around these parts
Pbread you got that low with lowering links? Is that ur sport plus setting 2?
I have lowering links but not that low.....
Thanks in advance
Old Sep 16, 2014 | 08:36 PM
Pbread's Avatar
No I don't run her that low... I run about 1" lower in the rear and .75" lower in the front than the original height in sport plus (see pic of my fixed height I run in sp). You can however technically go 2.5" lower than stock height with the links but I haven't performance tested it this low but do know it can be done without it hitting the wheel wells at under 5 mph
adnanm3
Nov 22, 2023 02:43 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
kensworth
Cayenne 955/957
Sep 9, 2015 05:45 AM
