tpms removal
Old Nov 27, 2014 | 12:33 PM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
tpms removal
I am waiting my new wheels and was wondering if I can remove the tpms from my oem 19 wheels to the new aftermarket wheels?
Old Nov 27, 2014 | 01:51 PM
Gus_Smedstad's Avatar
Gus_Smedstad is infamous around these parts
Absolutely, though you probably want new valve stems if you do that.
A TPMS sensor consists of a couple of parts: the winged sensor contains the electronics, and the valve stem which screws into it (parts C-F in this diagram).
The issue is that removing the stems damages them, so you want new ones when changing wheels.
Old Nov 27, 2014 | 02:02 PM
Where can I buy them ?
Old Nov 27, 2014 | 02:13 PM
They're a common, universal part. Any tire store should sell them.
If you want to buy them yourself, places like J.C. Whitney carry them.
Old Nov 27, 2014 | 03:00 PM
Old Nov 28, 2014 | 01:05 AM
Originally Posted by Logimind
Keep in mind that cayenne and panamera sensors are the same if you have some extra from your old car.
Also most tire shops should switch them without damage.
Its better for me to contact the agency where I am buying the wheels and the tires and ask them to put new tps
Old Nov 28, 2014 | 06:41 PM
TGED's Avatar
TGED is infamous around these parts
Are you sure TPMS sensors are universal? Factory wheel packages from Porsche have 2 versions for the same wheel/tire depending for pre or post face lifted Panamera. The version for the current Panamera has TPMS II which I assume is different from TPMS I for the previous Panamera.
Old Nov 28, 2014 | 06:44 PM
The sensors are highly specific. The valve stems are a universal part. Look at the diagram I posted - part B is the section that must match the car.
markj
911
Apr 7, 2016 05:44 PM
AM v12v
Sep 7, 2015 02:17 PM
Wildcat1212
Sep 7, 2015 11:31 AM
B8_RDC
Sep 3, 2015 07:13 PM
