strange sound symptome help
Old Oct 25, 2015 | 06:00 AM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
Hello dear 6speed member !
I have a problem with my ptt. At 5000 rpm it makes a high frequency sound , kind of whistle sound.I dont think it has to do with turbocharger or intake because boost is ok . Made some research and a solution could be engine belt ?
Maybe it needs to be replaced or maybe water pump is going bad and it doesnt spray the belt with thr neccesary water requirement .
Another problem can be camshaft . Next time I will go to the shop to check them because 2 panamera 4s had camshaft failure here .
Any opnion and experience is greatly aprecciated
Old Oct 26, 2015 | 04:12 AM
Thanks for the replys ! The assistance in the panamera forum is great
Old Oct 26, 2015 | 06:09 PM
P.Viby's Avatar
P.Viby is infamous around these parts
You are sure it is not the waste gate from the Turbo's you are hearing ?
You can check the engine belt by spraying a LITTLE WD-40 on the belt while the engine is running. If noise stops - it is the belt.
I doubt the camshaft will make the noise you described.
Old Oct 27, 2015 | 01:55 AM
Or it can be the pdk . It does it at 5000 rpm going full throttle , mostly when engine is cold . So maybe it can be the pdk switching to another gear.
Old Oct 27, 2015 | 02:06 AM
P.Viby's Avatar
That is also possible.
calexand
Nov 5, 2015 01:05 PM
solrac6262
Oct 8, 2015 12:55 PM
bonemechanic
Cayenne Turbo
Oct 6, 2015 08:15 AM
Peach PTT
Oct 5, 2015 04:27 PM
drkbrent
Oct 1, 2015 07:30 AM
