need TPMS
Old Dec 3, 2015 | 09:20 PM
2thfxr's Avatar
2thfxr is infamous around these parts
need TPMS
I am putting snow tires on a used 2012 P4 I just picked up. I have OEM wheels but no sensors. Do I need OEM TPMS sensors or are some of the aftermarket ones I see for sale on ebay ok? What frequency does the 2012 use?
Old Dec 3, 2015 | 10:51 PM
my_tom_a's Avatar
my_tom_a is infamous around these parts
I believe that Porsche TPMS system operates over the 433Mhz frequency. I bought aftermarket wheels but was suppose to get OEM TPMS modules installed with my tires, however my car does not recognize any of the tires. I've not contact the vendor to confirm what TPMS models they installed. If you are purchasing outside of a Porsche dealership (overpriced) I'd confirm the frequency of their modules and make sure that they measure up to the correct frequency.
Old Dec 4, 2015 | 04:24 AM
MrPrice's Avatar
MrPrice has much to be proud ofMrPrice has much to be proud ofMrPrice has much to be proud ofMrPrice has much to be proud ofMrPrice has much to be proud ofMrPrice has much to be proud ofMrPrice has much to be proud ofMrPrice has much to be proud of
The frequency did change, I think in 2014 and there is a relearn procedure that can be done (one was 315 the other 433 if I remember correctly) as well.
Old Dec 6, 2015 | 09:23 AM
TTCarrera's Avatar
TTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of light
Careful.
I've bought aftermarket 433 for a 2013 Cayenne GTS and they worked great. Saved several hundred dollars.
I then bought aftermarket 433 for a Macan Turbo and they did not work. Dealer put on 433 OEMs are they worked. Said there is something "new" in 2015+ TPMS system.
Spent about $400 on the aftermarket ones for the Macan plus mounting and then about $650 in parts & labor for the OEM. A sad day.
Ekaplan1020
Nov 10, 2015 06:42 PM
WheelB
Other British Cars
Nov 10, 2015 11:57 AM
Southpaw07
Nov 9, 2015 05:45 PM
BlazinPond
Cayenne 958
Nov 9, 2015 04:46 PM
TAILWAG
Nov 5, 2015 08:20 AM
