Remove Side Markers?
Old May 31, 2016 | 02:07 PM
nephew's Avatar
nephew is infamous around these parts
Is there a way to easily remove the side markers (so they can be painted or filmed)?
Old May 31, 2016 | 02:50 PM
OEkun1's Avatar
OEkun1 has a spectacular aura aboutOEkun1 has a spectacular aura aboutOEkun1 has a spectacular aura about
Yes, it involves removing the front wheels (easy access) undoing the fender liner, unplugging the lights and pushing them out...I just did mine over the weekend. If you search you can find the vendor that sells painted side markers.
Old May 31, 2016 | 05:08 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
the 911 used to just pop out using a credit card from the out side light... if they just pop out maybe you can avoid all that work.
Old May 31, 2016 | 07:59 PM
OEkun1's Avatar
Sadly they don't, at least I wasn't willing to potentially damage the paint. Besides its super easy the recommended way.
Old Jun 1, 2016 | 05:56 AM
cerbomark's Avatar
Understood. If I saw the back of the new ones I d be able to tell if they come out the easier way though. Do they make clear markers. I did those on my 911 and may do them on this car ? Do you have a link to changing them?
Old Jun 1, 2016 | 09:29 AM
OEkun1's Avatar
I have my OEM ones that I'm willing to part with if you have a shop and want to paint them to match your vehicle.
Old Jun 1, 2016 | 12:40 PM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
Did you try youtube? They dealer told me that was the method to remove them on my cayenne, but I saw a video of how you slide fishing line behind the marker from the front, then work it back (half way) until it stops. Then you pull on the line and it unclicks the tab. Then it pops right out. Not sure if it's the same on the pany, but it's worth looking into.
Old Jun 1, 2016 | 12:52 PM
OEkun1's Avatar
For some, taking the wheels off allowed me to look at other things (brake pads, suspension configuration for the pending springs install).
Old Jun 2, 2016 | 09:14 AM
cerbomark's Avatar
I ll trade a set of amber 997.2 ones .
Old Jun 2, 2016 | 10:07 PM
OEkun1's Avatar
Old Jun 8, 2016 | 01:17 PM
tonyep's Avatar
tonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of light
You do not have to remove the front wheels, just turn them the opposite direction on the side you're working on. There's a small hole where you insert a screwdriver to push the side marker out.
I had the bulb painted black as well with some high temp spray paint so they won't shine through the paint.
RAudi Driver
Cayenne 958
Jul 23, 2016 11:34 PM
jaygotti
Jun 1, 2016 10:13 PM
rickjaffe
May 30, 2016 06:56 PM
VGLNTE1
May 30, 2016 11:02 AM
HolmaN
May 26, 2016 06:17 AM
