panamera fault code meaning
Old Jun 2, 2016 | 12:49 AM
Dtracing's Avatar
Dtracing is infamous around these parts
Default panamera fault code meaning?
hi,
i have diagnose my panamera 970 3.6l v6 2011 model with durametric system, i would like to know where i can find the meaning and what to do regarding those fault code?
i get some default code as follow:
Panamera. Engine module EMS sdi 6.1 >> fault code = P065A
Electronic parking brake >> fault code = C10DE00
Heating and air conditioning >> fault code = 12656660 / C12014 and 12656778 / C1208A
Can gateway >> fault code = 1538 / 602 and 1539 / 603
Door FL and Door FR >> fault code = 920
Door RL >> fault code = 2115
Radio play 3.1 cdr >> fault code = C123
thanks for the help.
Old Jun 2, 2016 | 09:11 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
I couldn t find help on my 997 when this happened.. If no lights came on I would clear all. Best I could find is that some codes get set off and really have no meaning to us. I think maybe sometimes a batter change or something like that can interrupt and set codes off.
Old Jun 2, 2016 | 03:29 PM
XLR82XS's Avatar
Was the check engine light on or did you just scan to check for faults? IF the light was not on I would purge all faults and check again if a MIL illuminates.
They could be low voltage codes - (i.e. the battery was run low at one point)
Old Jun 2, 2016 | 03:47 PM
Dtracing's Avatar
Hi to all and thanks for your replies,
nothing shows up on the dashboard, no light, no messages, i made a scan with Durametric tool, then it show up all those code, after that i cleared all the code , i turn off the ignition and turn it on again, two code remain which was the
I scan the car because last time the driver got an overheating alert on the way back to his home the car was send on slide truck to my workshop, two weeks after i tried the car for at least a 15 km run in supersport mode and high speed driving , the temperature never goes up over 90 degrees celsius, weird...
May 17, 2016 11:09 AM
Brunno Cortes
Apr 3, 2016 10:33 AM
18ri
Cayenne 958
Mar 31, 2016 11:15 AM
