Durametric code
Old Apr 2, 2016 | 07:07 AM
Brunno Cortes's Avatar
Brunno Cortes Is a GOD !Brunno Cortes Is a GOD !Brunno Cortes Is a GOD !Brunno Cortes Is a GOD !Brunno Cortes Is a GOD !Brunno Cortes Is a GOD !Brunno Cortes Is a GOD !Brunno Cortes Is a GOD !Brunno Cortes Is a GOD !Brunno Cortes Is a GOD !Brunno Cortes Is a GOD !
Hi guys! I am always with those codes on my turbo. I erase and they come back. What should it means? Bad MAF? MAP? O2 sensors? Tks for help
EVT 775 kit with COBB custom tunning accesport
Old Apr 3, 2016 | 10:16 AM
COBB Tuning's Avatar
COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !
Hi Brunno!
If you have a custom tune already I would contact your tuner.
If you are running one of our off the shelf maps I'd recommend reaching out to a Protuner to get a map that will work with your EVT 775 kit. Many of our Protuners are very capable of remote tuning.
It looks like you are in Brazil and the pump fuel there is generally 25% ethanol and 75% gasoline which may account for some of the discrepancy. However I'd more expect a system too lean code than rich.
Generally a system too rich/lean code is brought on by the long term fuel trim corrections hitting a preset limit in the ecu causing it to illuminate the check engine light.
Out of curiosity have you checked your fuel pressure regulator vacuum reference line? If this comes off you will have a vacuum/boost leak but will also be running higher fuel pressure at idle and lower fuel pressure under boost.
Old Apr 3, 2016 | 10:33 AM
Many tks!!!!
EVT 775 kit and cobb tunning
Feb 23, 2016 09:51 AM
Oliver Goldsmith
Feb 22, 2016 06:47 PM
mdurbahn
Feb 19, 2016 02:24 PM
SuncoastParts
Feb 19, 2016 08:27 AM
