Panamera Headlight Washer nozzle install
Old Dec 31, 2016 | 05:16 PM
adiliyoo's Avatar
adiliyoo is infamous around these parts
Hi guys,
I haven't been on here for sometime now and since then switched from cayenne to Panamera.
The other day I went to see my friend and he said "did someone steal your headlight washer?" I looked and one of the nozzles was gone. I have no clue where it went, lol.
I got a new one and was trying to install it today thinking that it was just some sort of click system, put it in but it still comes out easily. Anyone knows how to install that? Thanks much
It looks exactly like this
Old Jan 10, 2017 | 06:22 PM
adiliyoo's Avatar
nobody knows? I tried just putting it in really hard, but it keeps flying out when I use the washer
Old Jan 11, 2017 | 07:33 AM
OEkun1's Avatar
OEkun1 has a spectacular aura aboutOEkun1 has a spectacular aura aboutOEkun1 has a spectacular aura about
There may be a clip on the back side. I hate to do this, but I'd suggest taking off the bumper to see what it looks like on the other side. Then you can be sure you have the appropriate pieces to properly secure it.
Old Jan 11, 2017 | 10:33 AM
adiliyoo's Avatar
probably is, i wonder if mine is broken since this thing wouldn't stay in there.
removing the bumper is way too much work,
I just ended up inserting it and just disabling the headlight washers, lol
Old Jan 11, 2017 | 01:39 PM
mziegler38's Avatar
mziegler38 is infamous around these parts
Why not discuss this with your service personnel?
Old Jan 11, 2017 | 02:33 PM
OEkun1's Avatar
HA...not having it functional would bother the snot out of me!
Old Jan 11, 2017 | 02:34 PM
OEkun1's Avatar
This is an option if you're not willing to try and tackle it yourself, although it doesn't seem to bother you enough.
Old Jan 11, 2017 | 04:08 PM
adiliyoo's Avatar
lol when i picked up the part I tried asking this the service guys. They basically said "pull up, we'll take a look at it. Oh, btw, you 40K service is due, lets do that right now too...its somewhere around $2K".
Old Jan 11, 2017 | 04:28 PM
NiceCar's Avatar
NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !
They take off the front bumper for the 40K service.
Old Aug 5, 2019 | 11:58 AM
mrwilliamsburg's Avatar
mrwilliamsburg is infamous around these parts
I'm now experiencing this problem on my 2013 Turbo. While slowly approaching a stoplight yesterday, I hit the headlight washer button only to see my passenger side headlight washer nozzle get ejected into the air. I was able to retrieve the spent nozzle assembly from the side of the road and have determined that the nozzle assembly (as shown in your pic above) is fine. Using a coat hangar to manually raise the top end of the pump from the hole in the top of the bumper, I have determine that the little plastic tab that engages the ridges on the shaft of the nozzle assembly has broken off. The proper fix is to replace the headlight washer pump. For cars no longer under warranty, it would certainly be worth trying to somehow pin the nozzle assembly to the pump using a very small countersunk screw.
In looking more carefully at the headlight washer pump and the nozzle assembly, I notice they both have part numbers that start with 997. Looks like this system (at least on the 970.1 vehicles) was borrowed from the 911 at the time. It's been many decades since I've had to do a "curb walk" looking downward (in shame) for parts that had just come off my car!
Old Aug 8, 2019 | 05:31 AM
HP41's Avatar
HP41 is a jewel in the roughHP41 is a jewel in the roughHP41 is a jewel in the rough
The "walk of shame" comment made my day!
I used to do that on a regular basis when I had either of my British cars (MGB and Jaguar) or really old, rusty Fords.
Old Aug 10, 2019 | 03:26 PM
tallpaul's Avatar
tallpaul is infamous around these parts
Considering how over engineered much of the car is, the headlight washer was a surprisingly unsupported. The install is pretty straight forward, put the new one in through the bottom and push it flush and snug. Then attach the lower hose. It literally just hangs there. This is also why you are not the only one to have it "disappear". Once the nipple on it gets weak, it breaks easily.
