A/C button light question
Old Mar 22, 2017 | 07:54 AM
pwc6t3's Avatar
pwc6t3 is infamous around these parts
When you guys turn on a temperature that requires heat (for example it is 50F outside and you set the inside temperature at 72F), does your A/C button light come on? I can't figure out why the A/C light should come on if you are in heat mode. It does this every time.
Paul
Old Mar 22, 2017 | 09:39 AM
2thfxr's Avatar
2thfxr is infamous around these parts
My P4 does not do that. I manually turn on the AC if I want that on.
Old Mar 22, 2017 | 09:43 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Maybe if you turn it on using the auto button the AC will light up ??
I can t remember but I do not turn my system on with the AUTO button and the AC light stays off.
Old Mar 22, 2017 | 11:56 AM
JimW's Avatar
JimW has a spectacular aura aboutJimW has a spectacular aura aboutJimW has a spectacular aura about
I always leave my AC on, when cooling or heating it pulls the moisture out of the air.
Old Mar 23, 2017 | 06:01 AM
cerbomark's Avatar
OK, I checked last night... If you have the AC button OFF and put the system ON using the FAN button the AC will stay OFF... If you put the system ON using the AUTO button it will turn the AC ON.... For example, if you put the DEFROST on it should put the AC. As stated, the AC will pull dampness out of air.
Old Mar 23, 2017 | 08:46 AM
pwc6t3's Avatar
Well that explains it, I always turn on the system using the AUTO button! I appreciated everyone taking the time to look at their car and report back for me, it really helped.
Old Mar 23, 2017 | 10:47 AM
XLR82XS's Avatar
Exactly. Keep the windows from fogging up.
