Please help! Panamera navigation GPS off current position
Old Jul 20, 2017 | 07:29 AM
bebeqq1231's Avatar
bebeqq1231 is infamous around these parts
Does anyone has issue with their Navigation off current position?
Old Jul 21, 2017 | 09:41 PM
knowspin's Avatar
knowspin has a spectacular aura aboutknowspin has a spectacular aura aboutknowspin has a spectacular aura about
I'm not familiar with Porsche nav systems, but many have a calibration function. Basically your antenna may not be receiving signals from enough satellites. Check your manual, if there is a calibration procedure, make sure you do it with a clear view to the southern sky.
Old Jul 25, 2017 | 10:53 AM
bebeqq1231's Avatar
Problem fix, i unplug the GPS antenna and plug it back after 2 minute. Back to normal =)
Old Jul 25, 2017 | 07:59 PM
orangeokie's Avatar
orangeokie is infamous around these parts
I can't figure out how to work the nav. Way too complicated for me. Basically useless.
Old Dec 30, 2018 | 12:51 PM
mziegler38's Avatar
mziegler38 is infamous around these parts
am having the same problem. Where is the antenna connection plug located?
Old Dec 31, 2018 | 11:18 AM
bebeqq1231's Avatar
it's behind the rear view mirror, may i ask have you install the video cam on your car?
Old Dec 31, 2018 | 12:33 PM
mziegler38's Avatar
No I don't have a video cam installed. The only thing on the windshield is a radar detector and an ezpass (tolls) device.
I never noticed a plug behind the mirror. I will look..
Old Dec 31, 2018 | 12:47 PM
bebeqq1231's Avatar
You might want to removed the rader, I think that’s the issue. Drive for couple days and it’s should be back to normal. Mine was the Vedio cam causing the issue. Try it and let me know.
Old Dec 31, 2018 | 01:58 PM
mziegler38's Avatar
Thanks for the tip. I will try that. BTW I did not find a connector behind the mirror. There is something rather large built into the mirror housing.
My Panny does not have a roof mounted antenna that my other two had.
Old Dec 31, 2018 | 02:01 PM
bebeqq1231's Avatar
I am almost 100 percent it’s cause by the rader
Old Dec 31, 2018 | 02:03 PM
bebeqq1231's Avatar
It’s a plastic cover behind the mirror, but try to remove the rader first. It should be back to normal.
Old Jan 1, 2019 | 11:50 AM
jtorrebl's Avatar
jtorrebl is infamous around these parts
For 2 days I’ve been getting a warning that speed limits based on GPS are not working. Last night my maps went completely bonkers. I’m driving in the oceans and in other cities. My iPhone navigation is fine though. Agree Porsche’s servers for gps down?
