Question about rear rim offset
Old Aug 1, 2017 | 04:04 AM
amgpan's Avatar
amgpan is infamous around these parts
Hi
Wanting to get advice if anyone knows;
Can our Panny fit 10.5" Wide with +35 offset. (ofcourse without rubbing)
Rim would be 22" Diameter
Thanks!
Old Aug 1, 2017 | 11:15 AM
orangeokie's Avatar
orangeokie is infamous around these parts
Here are some helpful tools . . . http://www.tyresizecalculator.com/ty...ace-calculator
https://tiresize.com/wheel-offset-calculator/
Old Aug 1, 2017 | 06:24 PM
amgpan's Avatar
Hi
Yes i use that alot, but i needed real world feedback from fellow panny drivers with this or similar setup to see if it looks flush and doesnt rub.
I saw a really nice red panny with black & red rims, he was running 11" + 45 offset and it looked great.
My proposed setup is only 3mm further out so it SHOULD be fine. But still interested to know.
Old Aug 2, 2017 | 08:44 AM
EKD74's Avatar
EKD74 is infamous around these parts
Originally Posted by amgpan
Hi
I have 21" / 11" ET 55 and then a 15mm spacer at the rear.
Front is 9.5" 50" and no spacer. I wanted to fit a 5mm spacer there but then the rim would touch the brake caliper (PCCB).
Also, the car is lowered 1" all around and I always drive at the Sport Plus setting for ride height and it has never rubbed.
I have 295 tire in the back and 265 in the front.
Old Aug 2, 2017 | 09:12 AM
Just A GTS's Avatar
Just A GTS has a spectacular aura aboutJust A GTS has a spectacular aura aboutJust A GTS has a spectacular aura about
Hi. I am not sure if you were reffering to my car.
I think 3mm wont me an issue. I have no rubbing at all even at the lowest setting of my stock air ride. Then again I only have 295/30/22s, I can't comment if you were to get beefier tires. As it stands now my rears are really flush with the 20x11 ET45 (including the 15mm spacers)
But to answer the OPs question, yes it will fit (the rubbing part will depend on the size of your tires).
Old Aug 2, 2017 | 07:54 PM
amgpan's Avatar
Hi "Just A GTS". Yes i was referring to your beauty.
Also thank you EKD74 for your input.
This is great info for me. I think im going to be cutting it really fine as i wanted to run 315's on the rear.
All good. Will keep on searching!
Thanks everyone!
Old Jun 11, 2018 | 03:38 PM
jmish's Avatar
jmish is infamous around these parts
hi amgpan
what setup did you us in the end?...I am look at a 10.5 wheel +40 offset in the rear 22".....do or anyone else on this forum know if 30/25/22 will fit with no issues or rubbing?
