Lowering Module - Panel Removal DIY?
Old 10-12-2017, 06:44 PM
hyboost's Avatar
hyboost is on a distinguished road
Renntech has good instructions and video on the wiring part, but does anyone have instructions, notes or advice on how to get to the lowering module? I read that its in the rear driver side panel in the trunk somewhere, but before I start removing random parts, I figured I'd ask if you guys had pointers...
(Its a 2014 GTS)
Old 10-16-2017, 09:06 AM
Lboogie78's Avatar
Lboogie78 is on a distinguished road
Go ghost lings.. so much better, easy to install and a whole lot cheaper....
https://www.ghostmotorsports.com/ghost-links
Old 10-16-2017, 07:08 PM
hyboost's Avatar
Thanks for the link, those look good. But I already have the lowering module and was looking for adjustability on the fly since it’s the wife’s car. Planning on the install next weekend, was hoping for some hints on how to get to it to avoid the guessing.
Old 10-17-2017, 12:33 AM
ArneR's Avatar
ArneR is an unknown quantity at this point
Just a small tip for those of you who want to buy the lowering links. Do NOT buy them from this company. They are useless.
http://www.ebay.com/itm/PANAMERA-POR...ZRzIRo&vxp=mtr
Old 05-19-2018, 02:55 PM
negb's Avatar
negb is on a distinguished road
Originally Posted by hyboost
does anyone have instructions, notes or advice on how to get to the lowering module? I read that its in the rear driver side panel in the trunk somewhere, but before I start removing random parts, I figured I'd ask if you guys had pointers... (Its a 2014 GTS)
have you ever managed this ? I'm in the process right now, have removed everything to get to 'him' , I will try to make some instructions, as it is FU^CKING UNBELIEVABLE job which is not described properly by any lowering modules makers
Old 05-19-2018, 04:00 PM
hyboost's Avatar
Yeah, did it a few weeks ago. Wasn’t actually too bad but all I did was pull back the side panel, removing the rear part and pushed it toward front of car. Gave me plenty of access to the module back there without having to actually remove the whole thing. From what I remember:
Remove the big rubber seal
Remove the stainless center lock plate
Remove 2 little plastic covers in side panel and take out screws holding panel
Remove screw under the stainless plate previously removed
I think that’s all I needed to do. Then the bracket holding the module is held by 3 nuts with decent access. Rest was well documented by the module instructions.
Good luck
Old 05-21-2018, 08:24 AM
negb's Avatar
I got stacked on this ''torx screw bolt locking device'' (p/n 97055564301) because that torx is too small for this bolt which thread is on locking glue and got damaged even without moving from place, only with plumber's pliers got it out ! Need to order new one.
Name:	97055564301 - Panamera torx screw bolt locking device 0.jpg
ID:	526196   Click image for larger version
Name:	97055564301 - Panamera torx screw bolt locking device a.jpg
ID:	526197   Click image for larger version
Name:	97055564301 - Panamera torx screw bolt locking device b.jpg
ID:	526198   Click image for larger version
Name:	97055564301 - Panamera torx screw bolt locking device.jpg
ID:	526199   Click image for larger version
Name:	Lowering Module - Panel Removal DIY.jpg
Old 04-09-2019, 09:45 AM
atwong1's Avatar
Emerging Sponsor
atwong1 will become famous soon enough
negb, can you please help me trace the wire connected to that board next to the hard to remove screw? I am trying to retrofit that rear shade and I am having a hard time finding that wire in the schematics.
