2018 Panamera 4 climate settings
Old May 19, 2018 | 10:15 AM
jhw's Avatar
jhw
jhw is infamous around these parts
AC settings reset to 72F and low fan every time I turn off engine and restart. Have to then turn ac to 68 , fan hi and set center vent to what I set last before turning car off. Very annoying. Is there a way so it stays as last set?
Old May 19, 2018 | 11:59 AM
riden's Avatar
riden has a spectacular aura aboutriden has a spectacular aura aboutriden has a spectacular aura about
If it’s like the 970, you have to tell the computer to use the last settings and you may need to make the setting then use the key button on the door. Then again, the 971 has 3 times the software as the 970 so might be different. Owners manual is probably a good reference for this.
Old May 22, 2018 | 01:55 PM
ciaka's Avatar
Yup, many settings set on key, but there are conditions to make it happen. Manual states so.
I think car on, doors closed, locked and in drive. Then settings stored to key.
Old May 23, 2018 | 10:38 PM
jtorrebl's Avatar
jtorrebl is infamous around these parts
save to seat memory. Numbered and key just in case
Old May 25, 2018 | 11:58 AM
Fkim011's Avatar
Fkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant future
You have to save to key and memory #.
Old Jan 17, 2019 | 06:15 PM
Byrdman's Avatar
Byrdman is infamous around these parts
I am so glad you posted this I was starting to think I was going crazy...this setting in my '18 Panamera 4 is literally the most annoying thing over the sound of the PDK when I come to a stop....anyone know how to address the climate piece? There are many days when I miss my 970 4S with all the buttons...they '18 is a wow factor inside for sure but the functionality leaves a little to be desired.
Old Jan 18, 2019 | 06:38 PM
mziegler38's Avatar
mziegler38 is infamous around these parts
All those settings must get saved to the key. After setting up functions as you want, save to key (on the door) then press the open button on the key farb 3 or 4 times to lock in the settings. You should be good to go.
Kyle951
Apr 14, 2017 10:08 AM
ksh937
Feb 25, 2017 11:38 AM
Wheel Experts
Nov 17, 2011 12:54 PM
JZRS4
Oct 30, 2009 09:20 AM
