This vibration is driving me crazy!
Old May 30, 2018 | 09:17 PM
skiracer13's Avatar
5 Year Member
skiracer13 is infamous around these parts
On certain surfaces and in certain conditions, the vibration and rattle is extremely annoying - all I have to do to stop it is to place my finger over the red marked area by the sunroof panel and press. How can I make this fix a permanent one? Any advice will be greatly appreciated.
Old May 31, 2018 | 05:12 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Well you can do it the right way and see how that panel snaps off and re install after checking the clip on the loose area or just see if you can wedge a small piece of cloth or foam etc right under that area and gently tuck it in making that area tight.
Old May 31, 2018 | 05:21 AM
Tazer's Avatar
Tazer is infamous around these parts
I have the exact same rattle. I haven't done anything about it yet.
Old May 31, 2018 | 07:30 AM
rmjjensen's Avatar
rmjjensen has a spectacular aura aboutrmjjensen has a spectacular aura aboutrmjjensen has a spectacular aura about
Same problem over here - I've been ignoring it ...it is very annoying though...
Old May 31, 2018 | 06:06 PM
skiracer13's Avatar
5 Year Member
Well it looks to be a common problem w/o a solution - my car goes in for an oil change in a couple of weeks so I'll have my indy take a look at it. Sure would be nice to find an easy fix! It's really the only thing that's bugging me about the car. I sure love my PTT.
Old Jun 5, 2018 | 08:23 AM
RAudi Driver's Avatar
RAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud of
Go to audi and get the foam they sell . it's micro thin, a total ripoff, but works. I haven't been able to find adhesive felt that thin anywhere else.
Old Jun 5, 2018 | 08:39 AM
amgpan's Avatar
amgpan is infamous around these parts
Mine is the same, fixed it by taking the panel out, and adjusting the clips to put more tension on the panel, then click it back in
Old Jun 5, 2018 | 07:41 PM
skiracer13's Avatar
5 Year Member
I followed your instructions and did the same (found a great YouTube video on it) and then applied the felt as recommended by RAudi Driver - many thanks to both of you.
I won't get a chance to test it for another couple of weeks but I'll be sure to report back my findings as it was such a simple fix.
Cheers!
Old Jun 6, 2018 | 05:44 AM
rmjjensen's Avatar
Cheers!
Can you post the link to the youtube video? Thanks!
EDIT: Pretty sure it was this one:
Old Jun 6, 2018 | 08:32 AM
skiracer13's Avatar
5 Year Member
EDIT: Pretty sure it was this one: https://www.youtube.com/watch?v=jRJdWvGmQ1A
Yep - that's the video and the procedure took all of 5 mins and I took my time so as not to break any of the connectors.
And here's a pic of the felt strip I purchased from Audi parts dept and I applied it to the front of the dome in an attempt to further tighten up the offending rattle issue.
Old Jun 12, 2018 | 03:24 PM
skiracer13's Avatar
5 Year Member
I finally had several test drives to confirm this procedure has eliminated my annoying vibration in the sunroof lighting panel. Life is great again in the Panny.
Yotam Refael
Jul 27, 2015 01:38 PM
