Crazy vibration, lost 2 lug nuts on the highway. Almost lost a wheel at 60mph eek...
So after months and months of having my wheels on, two lug nuts decided to come lose. Yes I have a torque wrench so i'm thinkin maybe somebody was trying to steal my wheels or something I dunno..
I lost two lugs on the highway, the vibration came on fast and furious (yeah) by the time I safely pulled over the other three were hand tight (or loose), so I was seriously close to losing a wheel, scary stuff. Had my son in the car with me which makes matters even worse.
So, I need a new set of lugs with locking bolts. Not sure I wanna keep any of the lugs on my car anymore. I have 7mm spacer on the rear and the front and rear lugs are the same length, all about 7mm longer than stock set. Where can I get lugs from?
Not interested in titanium, (out of my snack bracket) looking for steel lugs with a locking set. Who sells em?
had something happen to my neighbour a few months back, think vandalism or theft was probably someone's objective when parked at the mall/work/etc.
I replaced all(20) lugs as he had lost one of them and the remaining were an older 1-piece style which were an issue for his car(Volvo)
I would just get new (optional spacer bolts) from Porsche directly, quality guaranteed and simple to find. Looks like the aftermarket one's you have/had are possibly 1-piece where the Porsche one's are two-piece(bolt/washer) which allows more accurate torqueing and is easier on the wheels surface, not mandatory in the slightest-but nice.
Cheers,
Cheers,
One of our very own vendors has a good deal on em: ECS Tuning
http://www.ecstuning.com/ES514297/ Maybe I can spray em black?
I would go with the oem also you could as you mentioned paint them I wonder if the non threaded part could be powder coated for a reasonable price and would it hold up?
i know they have a main website but this may help you find it.
http://rad-usa-direct.amazonwebstore.com/
Yeah, found those at the dealership, were $9.75 each
those look right but not sure they'll fit (?) says they're for a 914 !? is 52mm correct? yeah..
try these
.. but they *may*? be the same.
http://www.automotion.com/handr-dr-s...r-porsche.html
try these
try these
The link you sent say 996 997 Boxster and Caymen, I don't see 914...
i've had lugs snap. no fun at all.
52mm for a 7mm spacer is perfect as you say. 60mm if you happen to run a 15mm spacer rear.
says for p turbo..?? no?
no.. lol. was on the app guide on your ecs link. it say for "model" 914(?)
PORSCHE 911 (996) 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005
PORSCHE 911 (997) 2005, 2006, 2007, 2008, 2009
PORSCHE BOXSTER 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009
PORSCHE CAYMAN 2006, 2007, 2008, 2009
Let me ask you something. When you look at the application guide in the link you posted from ecs,
Does it say those bolts fit a 914 and not a 996 turbo?
I only ask because that info came from the link you posted.
It should have nothing whatsoever to do with my cache cookies or anything else.
I provided you a link to some h&r lug bolts from automation
I know will fit your car if running that 7mm spacer At the end of this day, that's all that will matter. Lol. Whatever, we know what you need.
