Rear door structure removal
Old Nov 7, 2018 | 09:56 PM
tastefulmod's Avatar
tastefulmod is infamous around these parts
There is an annoying rattle that's coming for my rear passenger door. I started taking things apart one by one to see what is causing this rattle and so far I am down to the structure that has the glass attached to it. I removed all the bolts but for some reason cant seem to get the rear end of the structure off. Has anyone done this? Is there a hidden bolt in the rear of the door that I might be missing?
Old Nov 8, 2018 | 08:54 AM
Just A GTS's Avatar
Just A GTS has a spectacular aura aboutJust A GTS has a spectacular aura aboutJust A GTS has a spectacular aura about
Pull the actual door panel towards you and up when all bolts are out. I had the same issue the first time I tried to take it off. Good luck.
Old Nov 12, 2018 | 09:39 AM
@Just A GTS thanks but I was looking for the structure behind that panel where the glass attaches to it. I figured it out over the weekend and finally found the source of the rattle. It was a loose bolt that seemed like it was never fastened from the factory or somehow came really loose. Will post pictures later today.
