oil extractor?
Old Dec 28, 2018 | 06:36 PM
cbwinters01's Avatar
cbwinters01 is infamous around these parts
oil extractor?
After doing the first oil change on my 2016 pseh today, wondering if there is a better way to do this than the standard drain through oil plug since the v6 has the oil filter up top. in the online Porsche instructions for the oil change, it mentions two ways to go at it: 1)drain out oil plug or 2)use an oil extractor to suck it out.
It may make sense to go with the oil extractor since (as noted) the oil filter is up top in the engine bay...a lot of time is wasted removing all of the screws in the under-body cover.
Anyone using an oil extractor on their Panamera?
Thanks,
cw
Old Dec 31, 2018 | 05:23 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
I ve used this before on Mercedes as they had a dip stick to go thru. The only issue with what you mention is will the extractor tube going into the filter port hit the bottom of oil pan. If this is a long term plan for you I would try the extractor and then after you feel it s drained remove the plug and see what if anything comes out.
FYI, My 2015 v6 Pana had the filter on the bottom so I never tried this method.
Old Dec 31, 2018 | 09:01 AM
Thank you for the response. The car does have a dipstick/tube as well, and the dipstick thankfully is fairly short and very straight. I mentioned the fact that the oil filter was up top since I know that most here have to get at it through the bottom. If i had to open up the bottom each time to get at the oil filter, it might not be worth going the oil extractor route.
As it is, after doing quite a bit of research on it, I went ahead and ordered one. Now I just need to wait another year to try it out...
Old Dec 31, 2018 | 01:47 PM
cerbomark's Avatar
Good, I d try going right down the dip stick tube. You ll feel it hit the bottom of the oil pan, hopefully.
Nick@Autogeek
Detailing
Apr 1, 2011 02:27 PM
wizness
Detailing
Aug 16, 2010 07:20 PM
detailjohn
Detailing
Jul 5, 2008 12:00 AM
jhon77
Jun 21, 2008 03:10 PM
bond
Jul 15, 2004 12:59 AM
