Car wont start
Old Oct 22, 2019 | 10:44 PM
ciaka's Avatar
I saw that one, the guy already had it out. Just trying to get info before I start, as there are many small tubes that if you are not careful, you may crack, and then a relatively simple job can exponentially become more difficult.
Old Oct 22, 2019 | 10:48 PM
NormalFellow's Avatar
NormalFellow is infamous around these parts
The boost T connector will definitely break or will need to be replaced when taking off the manifold as well as new gaskets and bolts.... The only tube that may crack is that one main one that goes across both valve covers to connect to the Air oil seperator. Other than that its a super straight forward process after that. The starter is held in by two easily accessible Reverse torx E10 bolts once the manifold has been removed. Heres the best pricing and shipping time for the manifold gasket and bolts... https://www.fcpeuro.com/products/por...-elring-484980
Old Oct 22, 2019 | 10:50 PM
throttle body seal and some carb cleaner to clean off the throttle plate and you are set
Old Oct 23, 2019 | 06:48 AM
Mazurda's Avatar
Mazurda is infamous around these parts
Good luck on tbis. The trial and error process with these cars is very extensive, glad all of our issues seem to be handled eventually (some quicker than others) but overall saving people thousands of dollars is a great thing. Hope this is relatively easy one for you. What year and mileage are you again, also what new battery to you end up going with..
Interstate mx 49 h8?
Old Oct 23, 2019 | 07:11 AM
ciaka's Avatar
I got a new battery but car would not start with it, so I returned it.
The only option left now is the starter, so I will look tonite to see how extensive the intake removal will be. Hope easy.
Old Oct 23, 2019 | 07:18 AM
ciaka's Avatar
if I choose to do, I will get
- intake gaskets (bolts are affixed to intake, non removable)
- starter (thinking of OEM one from eBay found one new for under 200)
- If timely, will get throttlebody seal we will see
Anyone can see this still may not be starter? Thats where I am at now, My info says starter. Appreciate input.
Old Oct 23, 2019 | 07:24 AM
Mazurda's Avatar
After checking relay, fuses, battery replacement, that would have to be the most logically issue based on process of elimination, only concern is odd things can trigger unrelated items.
Old Oct 23, 2019 | 08:59 AM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
While your in there you might as well change the coolant thermostat housing with the updated (bolted) version
It will also give you a chance to see how bad the carbon buildup is
Old Oct 23, 2019 | 09:03 AM
DogWood's Avatar
5 Year Member
Duplicate - DUH
Old Oct 23, 2019 | 09:04 AM
DogWood's Avatar
5 Year Member
You might search for the coolant housing issue, here is one on a V6 but I suspect most of the procedure is the same ( it's in the V and everything needs to come off)
Old Oct 23, 2019 | 09:12 AM
ciaka's Avatar
the turbo has many hoses under throttle body, but should be similar. just bought bosch starter and accessories. will see how this goes. wont be here til monday so stuck driving the CTT (well, not really lol).
updates will come. Thanks.
Old Oct 23, 2019 | 01:03 PM
boogersryummie's Avatar
boogersryummie is infamous around these parts
Had the same symptoms a while back and it was a bad fuel pump.
Old Oct 23, 2019 | 01:50 PM
Deezflip's Avatar
5 Year Member
Deezflip is infamous around these parts
Hmmm, I was thinking maybe the keyless Entry and Drive with a dead battery on the FOB...but I think you should at least see a message on the dash not detecting the FOB
Old Oct 23, 2019 | 07:24 PM
ciaka's Avatar
You are right, there would be a message on cluster that cannot detect key, and I swapped that battery as well, while trying to eliminate any possibilities.
Thanks.
Old Oct 24, 2019 | 08:13 AM
skiracer13's Avatar
5 Year Member
skiracer13 is infamous around these parts
Have you confirmed the fuel pump hasn't failed?
