Porsche Entry and drive - door handles
Old Dec 3, 2019 | 04:13 PM
stealthn's Avatar
stealthn is infamous around these parts
Hi,
I have the keyless entry and I want to understand how the door handles work, it seems if you just touch them (on the inside) the door unlocks (without pulling). I ask because my drivers doesn't always work and sometimes (rarely) none of them work, so just trying to understand the mechanism/voodoo
Thanks in advance
Old Dec 3, 2019 | 04:18 PM
murci930's Avatar
murci930 is infamous around these parts
Mine went from faintly working to now sometimes, would be interested to see how they work as well.
Old Dec 3, 2019 | 04:45 PM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
a less than stellar explanation https://www.yourmechanic.com/article...oor-locks-work
there are 2 components to it, the RF from your key-fob and the touch plate of the door, which I suspect is capacitive
my door unlocking works pretty well, the drivers side lock button on the other hand is getting flaky
Old Dec 6, 2019 | 04:31 PM
stealthn's Avatar
So here’s what I know so far, the handles have sensors in them and the fix is to replace the handles themselves. I am hoping to talk to a Porsche tech tonight at a party so I will get confirmation.
Talked to Porsche and they are $203 (CDN) each - that’s with painting.
Old Dec 6, 2019 | 06:30 PM
murci930's Avatar
does yours work with other doors? Mine just stopped completely working after being spotty with the drivers but working with other doors. Is there a module that controls all of them or is it my key?
Old Dec 6, 2019 | 09:49 PM
stealthn's Avatar
Talked to the tech tonight, he said if it’s just the drivers could be the battery, but the resistor in each handle fail often. Replacement is a ***** he said as the whole window assembly in the door needs to come out. About 2 hours labor, and he said I don’t want to do it myself-he knows I work on all my cars, but I trust him when he says don’t do it yourself.
Old Jun 14, 2020 | 03:02 PM
murci930's Avatar
Did a little more testing this afternoon. If I try to use open or lock the doors, the display says “key not recognized” when the key fobs works perfectly.
I tried the lock/lock with the actual key, ignition then unlock button but still says “key fob not recognized”
anyone have any ideas?
Old Jun 14, 2020 | 04:12 PM
stealthn's Avatar
Battery in the fob?, there is also a special place to put the key near the steering wheel if it is not recognized. I forget where but I think it’s in the manual.
Old Jun 14, 2020 | 05:07 PM
murci930's Avatar
Replaced just to make sure, but didn’t work. Ill look at the manual now and try that, thank you!
Old Jun 15, 2020 | 11:42 AM
Stringbag's Avatar
Stringbag is infamous around these parts
My advice would be to find someone with PIWIS or Icarscan or similar - basically something that will allow you to see which antenna is sensing the key. You can walk around the car and it will tell you the strength of the signal. Without that kind of detail you are shooting in the (expensive) dark.
Could be key (do they both do the same? If so, unlikely), could be handle, could be interior antennas. Could be door module, could be gateway, Could be something else.
Old Jun 15, 2020 | 12:26 PM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Sounds like icarscan is a good bargain. But some reviews says it doesn't work. I guess it depends if you buy an original vs fake/clone. Do you mind sharing where you got yours? Hoping PIWIS arrives tonight but realized it says Monday the 22nd, which is next week.
Old Jun 15, 2020 | 12:55 PM
Stringbag's Avatar
I got mine from these guys - when it was on sale - and they shipped to the UK.
I have the older version (it’s orange and a little bit smaller than this one).
I got it a few years ago before I bought the Panamera - it was very useful for my cayenne (955) - lowered the suspension, enabled auto headlights, got to the bottom of Kessy issues and coded a few other things. It also worked on our VW golf & BMW Which seemed to never go wrong despite costing a fraction of the P cars...
Anyway, I was surprised that it works so well with the Panamera (2010). I’ve used it to recharge the suspension with Nitrogen, service the brakes and diagnose a bunch of other minor bits and pieces.
It is not PIWIS, and I am looking for an excuse to get a PIWIS II, but I’ve not found anything yet that it can’t do.
https://m.obd2tool.com/goods-10333-N...iABEgLud_D_BwE
Old Jun 16, 2020 | 06:16 AM
jzchen's Avatar
5 Year Member
@Stringbag Thanks. I'm probably the first person to be saddened that I got a PIWIS instead of the icarscan...
​​​​​​On the positive side it seems it's actually here in Los Angeles as of this morning. DHL tracking confused me yesterday. Item 5 was actually dated the 14th, while prior number item dated the 15th. Somehow it seemed processed through customs even before it left HK.
Old Jun 16, 2020 | 07:02 AM
Stringbag's Avatar
Don’t be!! It will be great!
Old Jun 16, 2020 | 09:47 AM
murci930's Avatar
Does this need a specific tablet/laptop?
