Car jump starters
Old May 8, 2020 | 07:42 PM
ciaka's Avatar
Car jump starters
Anyone have one of these car jump starters?
Thinking to get one and have ready in case.
Here is one: NOCO Boost Plus GB40 - 1000 Amp -
CLICK HERE CLICK HERE
Here is other: TACKLIVE T8 - 800 Amp Peak -
Any recommendations for trickle chargers?
Old May 9, 2020 | 04:00 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Amazon had some sort of flash sale I believe last Cyber Monday, and I bought a NOCO GB150 for around 50% off. I got to try the USB charge port but it does not support high output, (tried to charge my son's Chromebook but wasn't able to). I never got to try to jump start anything with it.
Costco carries a 4A Duracell charger/maintainer that is $10 cheaper in store than online. I like it so far. I now have 2.
Old May 10, 2020 | 10:54 PM
ciaka's Avatar
I just pulled trigger on noco gb40. We will see. The 1000cca is BS though, no way this small thing can supply 1000 amps. Saw many reviews even some where they boosted cars that were in junk yard for couple years and worked fine. Guess we will see in near future.
Old May 11, 2020 | 07:44 AM
stealthn's Avatar
stealthn is infamous around these parts
I have a small Cobra booster, it’s surprisingly powerful for such a small unit
Old May 15, 2020 | 09:30 PM
jzchen's Avatar
5 Year Member
Don't worry about that. When I bought a LiFePO4 battery for the Prius it weighed 9 lbs vs 28 lbs for the AGM. BUT, it also has a built in back up battery if you drain the main one! You get what you paid for with regards to jump starting. I just wasn't impressed with the weak USB. (Hopefully yours is better).
Old May 16, 2020 | 02:36 PM
Porscheman33's Avatar
Porscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud of
Amazon Amazon
This is what you want. I've jumped so many cars with this thing. My neighbors van sat for 5 years, one hook up on my box it started right up first try.
It holds a charge as well. I charge it every 3 months.
Old May 17, 2020 | 09:41 PM
ciaka's Avatar
Great info. Thanks. I ended up with GB40. Nice and small, we will see how it works, hoping tomorrow. Thanks.
Old Jun 6, 2020 | 09:46 AM
jzchen's Avatar
5 Year Member
Got a case and quick charger which arrived yesterday from Amazon. Haven't opened the quick charger package yet...
Please excuse the background.
Old Jun 6, 2020 | 01:09 PM
ciaka's Avatar
I got the noco GB40 starter. Awesome. Did the trick on my dead batt. Looked for reasons to use and always started. Even f350. On first try.
Old Jun 7, 2020 | 03:27 PM
murci930's Avatar
murci930 is infamous around these parts
Question: as far as charging the battery, where is the best place to do so? Jump points or directly to the battery?
Old Jun 7, 2020 | 06:41 PM
jzchen's Avatar
5 Year Member
I use the jump points under the hood. I don't know if it's better than direct connection to the battery, but so far I am happy with the results.
Old Jun 8, 2020 | 10:04 AM
Nikita4Ever's Avatar
Nikita4Ever is infamous around these parts
The NOCO is not very good. It’s overrated .
Old Jun 8, 2020 | 10:16 AM
jzchen's Avatar
5 Year Member
https://youtu.be/JN8A2nIMUWA
Thank you for sharing this video. Why did the NOCO start at such low voltage? Was it not fully charged? Strange...
Old Jun 9, 2020 | 07:50 AM
mziegler38's Avatar
mziegler38 is infamous around these parts
Per the video testing, the AUDEW unit was the best.
MotoJB
American Muscle
Sep 19, 2025 12:06 PM
Money2536
Garage Forum
Sep 1, 2016 03:37 AM
Most-Wanted
Track & Autocross
Oct 20, 2015 07:37 PM
mikegr
American Muscle
80
Mar 8, 2012 11:34 AM
