(865) Thermally & Noise Insulated Glass
Old May 12, 2020 | 06:31 PM
orangeblood18's Avatar
orangeblood18 is infamous around these parts
I have a 2016 Panamera Turbo S that has the (865) thermally & noise insulated glass. It has tint on the window as well. Does anyone know for sure if the (865) thermally & noise insulated glass came from the factory with the tint integrated into the glass? Another words, no film applied on top of the glass. The glass does have the film applied on the inside of the glass. I can see and feel the lip of the film. I have a scratch on the inside of the passenger's side front window. I took the car by the dealer and they said warranty would not cover the scratched glass/tint due to aftermarket tint applied. They said the (865) thermally & noise insulated glass has tight tolerances and applying tint on top of it makes the glass really tight against the felt and/or plastic piece that keeps the dirt out and if a dirt particle does wedge itself between the glass and felt/plastic piece, it will cause the glass/tint scratch. Just want to be sure that this sounds right and if anyone has had this problem? Thank you for your help.
Old May 12, 2020 | 10:06 PM
nischalr's Avatar
nischalr is infamous around these parts
From what I understand, the thermally insulated glass has a light reflective tint layer sandwiched in between the two layers of glass. Scratching aftermarket tint is a known issue on the Panamera's with or without the thermally insulated glass due to the tight tolerance as you described and the lack of felt on the inner lining of the glass/door interface. This may be exacerbated on the thermal glass optioned cars due to the possibly thicker overall profile of the double layer glass sandwich.
Many have had tint done with the installation of moleskin/felt on the inner aspect of the door panel to reduce scratching but this requires a very capable installer or the removal of the door panels by a qualified mechanic first.
I have seen kits from www.tintprotector.com used in the past with good success.
I have had two Panamera's and so far no issues with scratching despite having thermal glass on both of them without having the moleskin/felt installed. I attribute my luck to the fact I never was one to open the windows too often, and the short duration of my ownership.
long term, I think, replacing the tint every few years might be the solution if you want to avoid the moleskin/ felt option.
Hopefully others will chime in, but I feel confident that what the dealer is telling you is correct.
SlowButSteady
Jul 29, 2019 01:39 PM
GladiatorOwner
Apr 4, 2015 10:31 PM
cavsct94
Sep 15, 2011 11:37 AM
Carbon
Jul 31, 2011 03:50 PM
dinorocz
Jan 30, 2009 09:11 AM
