2011 Panamera Transmission Distance Sensor
Old Dec 3, 2020 | 07:54 AM
Supdon1012's Avatar
Registered PM
Supdon1012 is infamous around these parts
Angry 2011 Panamera Transmission Distance Sensor
So I'm driving I get a transmission fault on the dash, stop turn the car off and the car drives fine. Next morning start the car no issue drive 1.5 miles to get gas and I get the same fault but this time the car thinks it is in neutral. Go to porsche and they say it is the distance sensor in the valve body chassis and will need a control unit. Has anyone experienced this issue?
Old Dec 8, 2020 | 06:49 PM
ciaka's Avatar
Look up my DIY thread for transmission fault, pdk shift rod sensors replacement.
Read entire thread. If you have duags, scan when you get this fault. If you see shift rod sensor errors, you are in luck, for I laid out before you, entire process to fix, and save thousands of dollars, literally.
Old Dec 8, 2020 | 06:57 PM
ciaka's Avatar
Old Dec 21, 2020 | 12:53 PM
Supdon1012's Avatar
Registered PM
The problem came down to the valve body chassis, where the sensor is located. Got the part changed and I am back on the road, and yes it was costly.
JTMHolland
Nov 17, 2024 04:05 AM
DavidIn
Oct 21, 2020 08:52 PM
tastefulmod
May 14, 2020 10:54 PM
bebeqq1231
Jul 28, 2019 09:39 AM
Dtracing
Sep 27, 2016 09:31 PM
