Help with errors and codes
Thanks for the update about the lighting issue! (Glad I paid attention over on the Candlepowerforums). I can understand a filament and the halogen cycle... Didn't think you'd ever need to change a gas discharge bulb since there is no filament, until it failed...
Best of luck on a quick solution on the suspension!
About the light, I noticed after I replaced the bulbs and the ballasts that I now have an icon of a headlight that is flashing Amber. Any idea what that could be? I remember you saying the bulb releases gases, would the headlight seal needing replacement cause this flashing Amber light?
I'm afraid I'm at the point where I'm in over my head. (Sorry about that. I just ordered yet another replacement SSD for my PIWIS 3 and noticed the company appears to be discontinuing it on their website)...
Sadly regarding the lights there's still something off. I found this neat guide although it seems quite a few of the icons are not loading for some reason, computer or internet is not being nice to me still waiting for FireFox to install and check if it's a browser incompatibility...
https://www.prestigeimports.net/pors...arning-lights/
I am still trying to figure out the suspension warning. It does pop up as soon as I turn on the engine. I wonder if low battery voltage might cause it cause it does take a quick second to crank it.
update: I took the car to O’Reilly’s and they did a battery, starter, alternator test and the starter failed. So I think the starter may be causing some of these errors. Will update as soon as I figure out the starter and how to replace the starter.
It's in the "V". I suggest to get the 8 gaskets for the "intake air distributor" as Porsche calls it. You'll be pulling it off. Good news is all those bolts holding it down are reusable. Also get the seals for the AOS/PCV valve. And the one Al bolt that holds the bracket to the passenger side of the engine.
weird thing is I pulled out the headlights yesterday and I still get the flashing Amber headlight icon. So I am not sure if it’s a “communication” warning LED or what.
what do you mean by “power at the module?”
Definitely agree with @shrike071 that something's amiss with your PIWIS. Easiest way to take care of a problem is to read the codes and determine what they mean, and find out likely causes. Still waiting on the replacement SSD, but if the error code is gone then there should not be any error lights. I get more error codes on my Foxwell NT510 Elite than I get error lights on the instrument cluster, not the other way around.
It's possible. So there are no codes in your PIWIS? I just fixed mine by activating Windows 8 Pro (both boot drives) with valid codes then upgrading to Windows 10 Pro. Then made a clone/backup. Both have "Fault Finding" shaded out (just checked a few moments ago) so I'm afraid I'm not going to be helpful looking it up. But yes Google the C1200C and someone shared what looked like PIWIS fault finding. One of the solutions was reflash/program the ECU...
