Help Needed - AC Blower Switch Panamera
Old May 25, 2022 | 09:34 AM
spqa's Avatar
spqa is infamous around these parts
Hello All, I can not manually adjust the fan speed on the driver side of my 2010 Panamera Turbo after my cell phone fell on the switch. Is there a way to fix this so I can manually adjust the fan speed or will the switch need to be replace? Appreciate anyone feedback. Thanks in advance and Blessings.
Old May 27, 2022 | 08:11 AM
sac02's Avatar
sac02 has much to be proud ofsac02 has much to be proud ofsac02 has much to be proud ofsac02 has much to be proud ofsac02 has much to be proud ofsac02 has much to be proud ofsac02 has much to be proud ofsac02 has much to be proud of
To clarify - blower speed will change as expected if you put it in "auto" and raise/lower the temp?
It is only the function of the manual fan speed switch that seems to be non-functioning?
If so I'd agree that yes the switch is at fault.
Old May 27, 2022 | 11:26 AM
spqa's Avatar
Thanks sac02 and was wondering if there was a way to correct the problem or if the switch/console needed to be replaced. Blessings
damirg
May 2, 2022 04:09 AM
JamesWalker
Oct 4, 2017 05:11 AM
RichS2010
Nov 19, 2010 03:39 PM
Pierre996TT
Jul 22, 2009 01:37 AM
