Leaking Plastic Coolant Pipes
Old Jul 5, 2022 | 03:04 PM
Gabbypig's Avatar
Gabbypig is infamous around these parts
I changed the oil this weekend and upon removal of the belly pan I noticed are fairly large area of coolant stains on the pan. After a quick search it was apparent the plastic coolant pipes in the oil cooler and alternator coolant circuit have become brittle and leak. When a wiggled the rubber portion of the circuit the plastic connector on the alternator snapped off easily. I have ordered the parts and await there arrival. I have had a faint coolant smell for a while and have had to top off the system roughly every 5,000 miles.
Has anyone done this work before? I am concerned about access for the alternator connector as it can't be reached from above and looks too cramped to get a torx wrench on there. The pipe in question is shown on the first picture with the blue line on the part. The second picture is from the area near the oil cooler.
I know this has been an issue with the Cayenne models and now obviously on the Panamera. Not a good long-term design.
I've owned the car since new. 2012 Base Panamera with 93,XXX miles.
Alternator Coolant Leak
Oil Cooler Area Coolant Leak
Old Oct 1, 2023 | 12:22 PM
tonyhw206's Avatar
tonyhw206 is infamous around these parts
Same issue 2011 s 95k
Were you able to fix this? Currently researching before I tackle this project and double checking what else I should repair while I’m in here
sam08861
Bentley
Mar 15, 2019 03:56 PM
gh0stman
Cayenne 955/957
Jan 13, 2015 03:02 AM
kdog126
Cayenne 955/957
Jan 13, 2014 07:23 AM
porsche510
Mar 6, 2012 11:23 AM
82targa
Jul 22, 2008 07:44 PM
