Oil Pressure Fault
Oil Pressure Fault
I brought my Pan4 to Porsche for an AC issue. They found out this
report
1. OIL PRESSURE FAULT.
Comments: DURING VEHICLE SCAN NOTICED FAULT CODES PRESENT FOR OIL PRESSURE SWITCH OPEN CIRCUIT. INTERMITTENT. SOMETIMES WHEN VEHICLE IS RUNNING OIL PRESSURE FAULT WILL ILLUMINATE ON INSTRUMENT CLUSTER AND 0 PSI OF OIL PRESSURE ON ENGINE OIL PRESSURE GAUGE. IF VEHICLE IS RE STARTED SOMETIMES SENSOR WILL WORK. SUGGEST TO REPLACE OIL PRESSURE SENDER AND PERFORM OIL CHANGE. VEHICLE ANALYSIS LOG WITH THESE FAULT CODES CAN BE SEEN.
$1.2K to fix
Is it easy to DIY? The Pan4 is 8 yrs old, and 83K miles.
Thank you for your guidance.
report
$1.2K to fix
This is a common issue with no solution.
Like many others I have replaced the oil pressure sensor and the solenoid in the oil pump and its still the same.
Some owners even replaced the oil pump at huge cost and had the problem return a few kms later.
