Lower Control Arm Bushing Press Tool
Old Jan 24, 2024 | 07:53 AM
tallpaul's Avatar
tallpaul is infamous around these parts
Has anyone here replaced their lower control arm on car with a press tool? If so, anything special about the size of these bushing? Only my outer looks bad, figured I'd see if you could do on car press with these. Either everyone does it or nobody does because I haven't found much info on it.
Old Jan 25, 2024 | 07:27 AM
rheidtman's Avatar
rheidtman is infamous around these parts
My only experience is to completely remove the arm and use my free-standing press. I suspect you could rig a system to remove in place, providing you have enough access. A threaded rod, large sockets or PVC pipe could be used to fabric a simple press. Did something similar removing the rear wheel bearings on my 944 turbo.
https://rennlist.com/forums/964-forum/498717-wheel-bearing-puller-home-made.html
UKGT
Bentley
Mar 24, 2023 01:42 PM
FIRST_PORSCHE
Nov 5, 2019 07:38 AM
pat
Sep 8, 2010 10:50 PM
DM1
944 Turbo & Turbo S
Sep 25, 2009 01:09 PM
ThePunisher
May 21, 2009 01:43 AM
