AZ: 1992 Acura NSX
Old 03-08-2019, 10:07 AM
azcarguy's Avatar
azcarguy is on a distinguished road
AZ: 1992 Acura NSX
Year: 1992
Make: Acura
Model: NSX
Price: $50000
Mileage: 107200
Color: Silver
Location (State): AZ
Transmission: Manual
Drivetrain: Rear Wheel Drive
1992 Acura NSX
VIN: JH4NA115XNT001180
Color: Silver/Black
Miles: 107,3xx
Owners: 2 including myself
Price: $50,000 - Clear AZ title in hand
Carfax/Autocheck: Clear
Before contacting me please read all of the following information provided and have funds in hand or pre-approved financing in hand to purchase.
More pics: https://azmg.smugmug.com/Cars/1992-Acura-NSX/
Pics 1-15 are recent, the others were from the prior owner but show the current condition of the bottom of the car as nothing has really changed. Presenting my 2 owner Silver/Black 1992 Acura NSX. This car spent the last 26 years in southern California under the fastidious ownership of a true Honda/Acura physician/enthusiast) all of his cars are Honda’s/Acura’s). It was maintained at the dealer and then a single independent Acura mechanic. It was driven and enjoyed but car has always been parked in covered parking at his office and garage at home. Car has been well taken care of and has had an extraordinary amount of work done during my brief ownership here in AZ. Please see the details in the month/year/provider section and under the mechanical section further down.
If you have interest in the car feel free to contact me and I’ll gladly provide the service records for your review via email. Once we’ve done that if you decide you’d like to proceed with a PPI I’m happy to work with you as we have a local Acura dealer and they know the car well (and have offered me money for it on 4 occasions).
Chapman Acura
4600 E 22nd St.
Tucson, AZ 85711
tel520) 445-4061
Once you’ve done so, and if you’ve decided to move forward, the buyer will be responsible for placing a deposit on the car, arranging a time for me to drop it off and obtaining the report directly from Chapman.
Happy to answer any additional questions you have AFTER you review the following info.
- 6/2019: 108,043 mi - R&R oil pan seal, replace heater control valve / Chapman Acura Tucson, AZ
- 10/2018: 107,023 mi -R&R transmission, replace trans case, clutch, t/o bearing/Chapman Acura- 9/2018: Replacing factory muffler with SoS unit /Exhaust Works Tucson AZ
- 8/2018: 107,022 miles - Remove CCU to send to Brian K/Chapman Acura
- 6/2018: HVAC diagnosis and replacement of evap valve, LH Condenser, receiver, recharge/Chapman Acura
- 6/2018: 107,074 mi.- Refinish roof to restore original finish/Hoods Tucson, AZ
- 5/2018: 106,259 mi. - Full service- R&R ALL belts incl timing, valve adjustment, A/C conversion to R134, coolant flush, thermostat, axle seal replacement R side (12 mo warranty on parts)/independent Auto LA California
- 11/2017: 104,218 mi – Oil change, brake fluid change/Independent
- 2/2017: 100,560 mi – oil change/Independent
- 11/2016: 94,806 mi – oil change/Independent
- tel:11/2015 92,856 mi – oil change, replace pan gasket/Independent
- 2/2013 90,311 mi – oil change, valve cover gaskets (L&R), Vtech seal, radiator cap/Independent
*the list of service above goes back 5 year however records will be included for the car going back to day 1.
Maintenance: Always maintained at Dealer or marquee specific independent. Records included.
Mods: 100% stock other than an Science of Speed (SOS) muffler.
Exterior: 7/10 – This is a driver quality car with imperfections as any 26 old car would have. There are three dings (2 drivers door, 1 L Front lower nose) that can be removed via paintless dent repair, various rock chips on the nose from driving it over the last quarter century. I had the roof professionally refinished in factory black to eliminate a peeling clear coat issue on the drivers B-pillar at a cost of about $1500.00.
Interior: 8.5/10 - Nice condition with normal wear. The driver seat has an opening in the joint on the side bolster closest to the door (shown in the picture link), otherwise the interior is in very nice shape with a great dash, door cards and carpets. I have taken steps to replace things like the gear lever, the driver side underdash pad (one of the plastics mounts was broken) and have additional parts for it if desired (see available parts list below)
Mechanical: 10/10 – The car has literally been completely gone through mechanically by both independent and an Acura dealer. I’ve gone through the whole car from top to bottom mechanically which included a full service prior to driving the car home from CA. So as far as maintenance it’s the timing belt, water pump, plugs, valve adjustment, coolant flush, thermostat replacement, ALL hoses replaced using the SoS kit https://www.scienceofspeed.com/index.php/nsx/enpp/external-engine-components/genuine-honda-complete-coolant-hose-kit-left-hand-drive.html. In addition the AC was weak upon my return to AZ so ended up replacing the evap valve(OEM), LH condenser (OEM) and had BrianK rebuild the CCU. Brian has also done the audio rebuild in this car under PO’s ownership. Yes the car was in snap ring, and yes the snap ring gave out on me. However, it happened as was pulling away from the house with my hand on the shifter, so I was immediately able to recognize the slight forward movement of the shifter and parked the car and had it towed. The trans case was replaced with a factory unit while the transmission itself was completely unharmed and as a “while you were in there” item I had a new (OEM) clutch put in. The snap ring came out in two pieces due to my not having driven any more than 10 ft. Pic of the perfect trans internals is posted on the smugmug link. Lastly the car has zero modifications outside of the SoS muffler. So mechanically the car has essentially been rebuilt over the last 1000 miles. Compression numbers from my PPI below:
Cyl 1 190 Cyl 4 187
Cyl 2 190 Cyl 5 187
Cyl 3 200 Cyl 6 190
These items are available at additional cost and will be made available to all forum members once car is sold if not desired by the buyer:
- New center console (OEM) - $550.00
- New AC top AC vent (OEM) - $500.00
- Used stock shifter boot leather and used stock boot NSX-R - $180.00 both
- Authentic BBS LM wheels specific NSX fitment BFG KD tires specific - $2600
Note: Car comes with stock wheels, 3 factory keys, records, all books, manuals. Coffee table book, factory car cover w/storage bag.
ID:	532123   Click image for larger version
Old 03-08-2019, 10:57 AM
GT3 Chuck's Avatar
Administrator
Please post all info and photos here as required...no links
Old 03-08-2019, 11:03 AM
azcarguy's Avatar
There's too many pics just pm for the link.
Old 03-08-2019, 11:07 AM
GT3 Chuck's Avatar
Administrator
The link is still there, just deactivated...anyone interested can copy and paste into their browser...you should really post more than one here.
Old 03-08-2019, 11:13 AM
azcarguy's Avatar
Ok thanks, postged a couple more
Old 06-16-2019, 08:43 PM
azcarguy's Avatar
To the top with a $5K reduction in price.
Have been driving the car a bit and noticed oil seepage and that heater was not functioning properly so addressed both items with the local Acura dealer. Repair noted in original ad above.
Old 06-17-2019, 01:21 PM
brightoncorgi's Avatar
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Surprised the car is still available. Nice color, good mechanical condition and fair price. Good luck with your sale.
Old 06-17-2019, 02:51 PM
azcarguy's Avatar
Thank you, appreciate the positive comments. Fun car market seems to be pretty tough across the board for some reason.
Old 06-17-2019, 03:01 PM
choron's Avatar
choron is an unknown quantity at this point
Beautiful car! GLWS!
htown
12-21-2016 09:56 PM
EL GT2
02-16-2015 12:29 PM
SupraEgo94
01-26-2013 07:48 AM
MiamieNeSeX
06-17-2009 12:15 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
Quick Reply: AZ: 1992 Acura NSX
