FS/T: 1972 Pantera GT-5
this for sale has moderator approval...VSE Chuck
I am looking for a trade either up, down or straight across depending on value.
What I have:
1972 DeTomaso Pantera GT-5
This Pantera has had extensive modifications including body, interior, drivetrain, wheels and suspension.
The engine has been upgraded to a 418 CI Windsor Stroker. Full rebuild performed approximately 7,000 miles ago. Rebuild included full forged and balanced rotating assembly, 10.7 : 1 compression, Ford Performance Solutions CNC ported and polished aluminum heads with 225CC ports, custom ground 246 duration and 570 lift cam, aluminum Super Victor Jr. intake and a holley 750 carb. Coated headers and dual stainless exhaust. Engine Dyno'd at 530 HP and 520 FTTQ. Chassis Dyno'd 416 RWHP and 426 RWTQ. Aggressive mean growl. This thing moves!
Further cooling upgrades were necessary for the larger engine. So the car was brought to PI. Motorsports of Orange California where I had a full stainless Fluidyne 4 core radiator and electric fans installed. All the hard piping was replaced including two new stainless tanks in the engine bay. The 5 speed ZF trans was polished at this time (as an assembled unit). A high torque starter was fitted as well as four adjustable aluminum coil overs with 400 lb spring rates. A pair of new half shafts were installed as well.
While at the shop I had the interior redone. The seats were recovered with custom embroidery. New door panels, recovered the dash and front panel and carpets replaced along with custom Pantera mats. A new OEM windshield was fitted as well.
Wheels and tires upgraded as well with 17" Hall Pantera polished aluminum wheels. 13" rears and 10" fronts. JFZ brakes were fitted by the prior owner as well to replace the the small factory brakes.
Body and paint were done prior to my acquiring the car. Paint is approximately 15 years old and shows signs of wear. There are rock chips here and there and stress cracks above the front fender flares. Paint is ok as a driver, but does need to be resprayed to be perfect.
This car no longer has A/C, the ducting remains but there is no compressor on the motor. There are a few other minor things, such as slow windows and broken turn signal switch.
Overall a very nice Pantera. Always draws a crowd where ever she goes. I have owned it now for nearly 5 years and there are other cars I would like to experience as well. I guess I just can't own them all, something has to go to make way for something new.
I am looking for $45,000 outright or trade for your Porsche Turbo.
What I have:
Coil overs. 12-way adjustable and rebuildable aluminum billet shock absorbers. You can adjust the compression and rebound to your tastes. 400 pound spring rates. Stock controls arms and sway bars. I have never tracked the car and I rarely drive it. To be honest, I am a bigger guy and I don't fit in the car all that well.
See them here at: www.pim.net
